Prindle 18 rudder line rigging
9 Users
4 Reactions
(@fttoy)
[#23796]
Hi Everyone,
I recently purchased a P18 and am having trouble rigging the up and down lines that operate the rudders.
Can someone please expalin this to me or point me in the right direction? Also...what size line do I need for this assembly?
I've downloaded the Prindle assembly manual, but can't seem to find any info.
Many Thanks!
Posted : October 15, 2008 7:22 am
(@_removed-account)
Four Star Admiral Registered
Send me an e-mail to remind me (rightclick@mi-connection.com) to take some pictures and describe the setup for you. It's a bit of a PITA, but can be done. I do believe it's 3/16th", but don't go out buying anything yet until I've made sure. It has to be the perfect size to fit through the gudgeons and allow clearance for the tiller crossbar bolts to go through and in between the two lines.
Posted : October 15, 2008 7:48 am
(@fttoy)
I'll take pics ltr today and send to you.
Really appreciate your help!
Posted : October 15, 2008 7:52 am
(@doug-p182-590)
Just noticed I wasn't logged in and th epost was anonymous. Oops.
Posted : October 15, 2008 9:35 am
Dustin Finlinson
(@Quarath)
I do think 3/16 is right but it shouldn't be just any 3/16 needs to be high quality non stretchy stuff. I did mine a couple times this year and it's not to bad once you get the hang of it but it is hard to describe so pictures are good. I just the boat away for the winter but Doug doesn't put some pictures up soon I will see if I can dig out the rudder casting and snap some pics. In Fact maybe I can make it a Tutorial that can be posted for others as well.
Posted : October 15, 2008 1:06 pm
blockp
(@blockp)
3/16 is ultimately what I replaced mine with this year. I tried 1/4, but had a hard time raising the rudders. Changed again to 3/16 and much easier to raise them before they kick up on their own.
Yup, absolutely non stretch with many fibers making the pull up smoother.
Posted : October 15, 2008 2:55 pm
(@doug-p182-590)
Frank,
Here you go on the Prindle rudder gudeon line running. Use the strongest, non-stretch, 1/4-inch lines you can get. That's 1/4
for stock! I'm going to post links to the pics since they're fairly big in size. You can just download them:
Prindle rudder gudgeon line pic #1
Prindle rudder gudgeon line pic #2
Prindle rudder gudegon line pic #3
Prindle rudder gudgeon line diagram
The raising line goes out the top of the gudgeon casting so that it can be pulled back on the slot to act as a cleat. You can make that line long enough and tie it off on a snap-shackle so that the two rudder raise lines can clip together. This way to raise the rudders, you can pull on one line for both and use your feet on the rear crossbar for leverage. (I don't. I have them separate and tied off on lawnmower pull handles. I just raise each one individually.) The
lower" line can be shorter and you can tie them off on lawnmower handles. They don't take a lot of force to drop the rudders down and have them lock in place.
Make note of the line running in the last diagram. The raising line goes over the outer wheel, down over the FRONT of the white nylon bar, back over the BACK of the inner wheel and ties off in a knot inside the rudder. This way as you pull on the line, it first pulls up on the bar with the white nylon guide around it with the springs. This releases the rudder lock. The springs hold it down on the lock, the first tension to raise, raises the bar up so the rudder can then come up.
The lowering line simply goes over the middle wheel, down BEHIND all the bars and out to the rudder where it ties off in a know.
The tiller crossbar bolts should go THROUGH the two rudder lines. If there's slack in them, they'll move to either side to let the bolt go through.
Make sure to properly adjust the length of the rudder lock-bolt. You can adjust the rudder rake. The more rake on your mast, the more the rudders need to be raked forward. Most Prindles will want their rudder lock bolt almost all the way in as far as possible so that the rudder is raked fairly far forward. If it's in line with the stern or raked slightly aft, the boat will have lee helm and always want to fall off the wind. It will also make the helm real hard on your arms. Locking should be tight enough that they lock in, but with a hard slap of your hand to the front of rudder blade, it should pop out. This'll prevent grounding damage to your rudders.
A lot of the rake setting and stiffness setting you'll have to play with to see what works best for the boat. They all have a mind of their own.
Hope this helps.
Posted : October 19, 2008 5:43 pm
(@fttoy)
Can't thank you enough for posting this information!
Really, really appreciate it!
Frank
Posted : October 20, 2008 9:55 am
(@sloma)
Newby Registered
Hi. I just purchased 3/16
line to replace the rudder lines on my 1979 P18. The current 1/4
line that came with rudders when I purchased the boat last year seems to create too much friction.
The photos are great. The path of the lines is different than on my rudders though. One reason this seems to be so is that instead of a complete nylon covered bar the 1979 rudders have a single nylon sheave/wheel on the inside. Thus the lowering line goes over the outer wheel and the raising line goes over the middle wheel and back up over the inner wheel. It seems like the pull on the rudder might be better centered if the raising line went down over the inner and back up over the middle though. I might try replacing them this way, which brings me to the reason I was searching about Prindle rudders.
Does the end cap come off to allow easier threading of the lines? Or do you just feed the lines through with or without a guide? I am about to replace my lines and am looking for tips on the best/easiest way to do this. It looks like feeding the line through with a piece of stiff wire might be quick.
Thank you for your help,
Jeremy
Posted : November 4, 2008 4:24 am
blockp
(@blockp)
I taped my new line to the end of my old line and pulled it through. It worked out fine and I didn't have to thread it through the rudder arm or around the
wheels
I had one rudder line break on me and to get it back through the rudder arm, I straightened a wire hanger. Put it through the holes in the arm, then taped my line to it and pulled it back through.
Posted : November 4, 2008 9:21 am
(@paroikoi)
Newby Registered
I know I'm resurrecting a 17 year old post, but would anyone happen to still have the photos Doug B posted above showing the routing of the rudder up and down lines?  Just got a Prindle 18 that has the lines routed very incorrectly.  Thanks in advance!
Posted : November 2, 2025 1:33 pm
(@paroikoi)
Newby Registered
Nevermind.  For anyone who finds this in the future, there is a newer photo (still viewable) here: https://thebeachcats.com/forums/technical-help/p16-rudder-line-routing-question/
If that photo also disappears in the future, feel free to message me.  I've downloaded it.
Posted : November 2, 2025 1:51 pm
Philip reacted
@paroikoi Awesome, things like this is why I was so set on migrating all of the old forum content to the new ones.
So much good info.
Posted : November 2, 2025 2:07 pm
Philip and Cat Scratch reacted
westmatt
(@westmatt)
This is for the 16, but I think the Prindle  rudders are all pretty much the same.
Posted : December 11, 2025 12:58 pm
