Racing Rules: "Overlap"
7 Users
(@isotope42)
[#30641]
Have you ever heard (or participated in) an on the water exchange like:
I'm going to need room at the mark.
No room - we aren't overlapped.
Oh yes we are - I need room!
If you don't know exactly what
overlap
means, you can't follow and enforce the rules on the racecourse.
In fact,
overlap
applies to several of the fundamental Racing Rules. It is referenced in rules
  • 11 - Same Tack, Overlapped,
  • 12 - Same Tack, Not Overlapped,
  • 17 - Proper Course,
  • 18 - Mark Room, and
  • 19 - Room to Pass an Obstruction.
What is
Overlap
Like other critical terms,
overlap
has a specific definition in the rules. I strongly encourage you to read the
Definitions
section closely. Unlike the other terms listed there, however,
Overlap
is defined in a backwards way. The terms
Clear Ahead
and
Clear Astern
are defined. If one boat is neither clear ahead nor clear astern of another, then the two boats are overlapped. Here is the full text of the definition:
One boat is clear astern of another when her hull and equipment in normal position are behind a line abeam from the aftermost point of the other boat’s hull and equipment in normal position. The other boat is clear ahead. They overlap when neither is clear astern. However, they also overlap when a boat between them overlaps both. These terms always apply to boats on the same tack. They do not apply to boats on opposite tacks unless rule 18 applies or both boats are sailing more than ninety degrees from the true wind.
When the terms apply
The terms
Clear Ahead
Clear Astern
, and
Overlap
always apply to boats on the same tack. The figure below shows four pairs of boats, in four different colors, on the same tack. Between each pair, the terms apply. Either one boat is ahead and the other astern, or the two are overlapped.
[Linked Image]
The terms also apply to boats on opposite tacks if both boats are sailing more than ninety degrees from the true wind, or rule 18 applies. The next figure shows four pairs of boats, in four different colors, on opposite tacks. The terms
Clear Ahead
Clear Astern
, and
Overlap
apply to the green and blue boats, but not to the yellow and orange boats. The green and blue boats are all sailing more than 90 degrees from the true wind, but the yellow and orange boats are not.
[Linked Image]
The only time that these terms apply to boats sailing 90 degrees or less from the true wind is if Rule 18 is in effect. Imagine that two boats were broad-reaching on opposite tacks towards a leeward mark and as they neared the zone, the wind shifted 45 degrees. Now one is sailing dead downwind and the other is on a beam reach. Ordinarily, with one boat sailing 90 degrees (or less) to the true wind, the terms would not apply. Because rule 18 is in effect, however, they do. See the following diagram:
[Linked Image]
to be continued...
Posted : January 23, 2015 7:00 pm
(@isotope42)
How to Determine Overlap
In order to determine whether or not boats are overlapped, you must look at their hulls, and their equipment in normal position. A few examples of
are
  • rudders in their down and locked position,
  • a retractable bowsprit when extended sailing downwind, or
  • a spinnaker flying.
Some examples of equipment not in normal position are:
  • a retractable bowsprit extended while sailing upwind,
  • a spinnaker with sheets or halyards loosed, or streaming out while hoisting or dousing (or shrimping),
  • a line trailing in the water behind a boat.
Equipment in normal position counts; equipment out of normal position does not.
Draw an imaginary line through the centerline of each boat. Draw another imaginary line perpendicular to the first at the aftmost point of the hull or equipment in normal position. If one boat (her hull and equipment in normal position) is entirely behind that second line, then she is
clear astern
and the other is
clear ahead
. If neither boat is clear astern of the other, then the two are
overlapped
Overlap on the Same Tack
Here is a diagram showing two pairs of boats on the same tack on a beat to windward. For each pair, I've drawn imaginary centerlines and perpendicular lines on the lead boat. Note that I've drawn the aftmost point slightly behind the hull because that's where the rudders are. The yellow boat is completely behind that line, so Blue is
clear ahead
and Yellow is
clear astern
. For the other pair, the trailing boat is not completely behind that line, so the boats are
overlapped
, and I've colored them both green.
[Linked Image]
I've drawn an equivalent diagram showing boats sailing a beam reach on the same tack. As above, Yellow is completely behind the aftmost point of Blue so Yellow is clear astern and Blue is clear ahead. The two green boats are overlapped.
[Linked Image]
And, finally, here's a picture showing same-tack boats on a run. I've drawn the boats as monohulls this time, because the program I used made it easier to show spinnakers that way. The interpretation is the same though. Blue is clear ahead and Yellow clear astern. Even though their hulls are not overlapped, their equipment in normal position is, so the two green boats are overlapped.
[Linked Image]
to be continued...
Posted : January 23, 2015 7:19 pm
(@isotope42)
Overlap on Opposite Tacks
Boats on opposite tacks may also be overlapped. Here are a few such circumstances. In the first, I've shown two boats on opposite tacks sailing a broad reach. The terms apply because both boats are sailing more than 90 degrees from the true wind (even if their apparent wind is directly abeam). I've drawn centerlines and perpendicular lines on both boats. Because neither boat is clear astern of the other, the two are overlapped.
[Linked Image]
Here is an example of boats sailing directly downwind on opposite tacks. As previously, I've drawn monohulls to show the spinnakers. Also, the fact that the port-tack boats are slightly angled is an artifact of the drawing program. Please ignore that imperfection. Once more, the Blue boat is clear ahead and Yellow clear astern. The green boats are overlapped.
[Linked Image]
Once more, here are two boats approaching a leeward mark. One is sailing (nearly) dead downwind on port tack, the other is on a starboard tack broad reach. Neither is clear astern of the other, so they are overlapped. This important relationship is often overlooked and misunderstood by boats sailing the rhumb-line.
[Linked Image]
to be continued...
Posted : January 23, 2015 7:29 pm
(@isotope42)
Overlap Between Multiple Boats
There is one more part to the definition of overlap. That is, two boats also overlap when a boat between them overlaps both. Even if their hulls and equipment do not overlap, two boats are overlapped when they are both overlapped by an intervening boat. Here is an example. In this diagram, the two green boats are not directly overlapped, but the orange middle boat does overlap both. Therefore, the green boats are overlapped.
[Linked Image]
Important Note! The boat that overlaps both must be in between them. Some people like to call that boat the
meat in the sandwich
. In order for overlap to exist, the meat must be between the pieces of bread. If there's no meat in the sandwich, then there's no overlap. I've illustrated that below. Although the Orange boat is overlapped with both Blue and Yellow, she is not between them. Therefore Blue and Yellow are not overlapped with each other.
[Linked Image]
I hope that helps,
Eric Rasmussen
US SAILING Certified Judge
Chair, SAYRA Appeals Committee
Posted : January 23, 2015 7:36 pm
(@_removed-account)
Four Star Admiral Registered
Thanks!
you rock
Posted : January 24, 2015 10:19 am
(@hobiefred)
Very helpful, thanks!!
Keep them coming.
Posted : January 24, 2015 10:41 am
(@brucat)
Rudder down and locked is arguable. In some classes, it is completely normal to sail downwind with a rudder up and locked. Upwind too, in light conditions (although I've heard of some young guns doing this internationally in all conditions).
Raising a rudder simply to create an overlap would be tough to defend.
Mike
Posted : January 24, 2015 9:22 pm
(@isotope42)
Rudder down and locked would certainly be
in normal position
. Rudder up may or may not be. Sometimes, raising the rudder would be normal. For example, a Hobie 16 going downwind in light air with one rudder up would be normal position. A rudder kicked up after hitting bottom would not.
I find it difficult to envision a circumstance where the boat ahead would raise a rudder in order to establish overlap.
Posted : January 24, 2015 9:43 pm
Jake Kohl
(@jake)
in normal position
Or be able to be THAT precise with when overlap is or isn't present.
Posted : January 25, 2015 8:11 am
Rob Vaden
(@redtwin)
Didn't Russell Coutts do that a couple of ACs ago on the last run to force Team New Zealand to allow him to gybe at the layline instead of push them off into oblivion?
Posted : January 25, 2015 8:14 am
(@brucat)
in normal position
Thanks Eric, I agree with that post, just wanted to clarify from your prior one.
Jake, raising a rudder can add a foot or so of length, people will notice that.
Mike
Posted : January 26, 2015 11:01 am
(@stank)
One Star Admiral Registered
Great stuff. Keep it up.
What was the thread topic name (so I can search for it) which you went over establishing overlap on a boat pre-start (or during the sequence).. Like a
J hook
to peel someone off at the boat end.?
Posted : January 26, 2015 12:12 pm
(@isotope42)
Originally Posted by waterbug_wpb
What was the thread topic name (so I can search for it) which you went over establishing overlap on a boat pre-start (or during the sequence).. ?
Do you mean the barging thread?
Posted : January 26, 2015 4:37 pm
(@isotope42)
I just noticed that I included the wrong diagram for boats on the same tack on a run. I'm surprised that nobody called me on that.
Anyway, here it is:
[Linked Image]
Posted : January 29, 2015 9:32 pm
