Racing Rules: "Right of Way"
14 Users
81.9 K Views
(@tcatman)
great debate!!!
Just because you THINK you are ahead.... at some intermediate point of the race course... the rules of the game are determinative... You have to plan your corners.
(now...I have been known to wait and wait and wait before tacking because...
the air is just not clean enough....
Always a huge mistake because it is putting me on port tack in the zone....)
Posted : September 10, 2014 9:47 am
(@brucat)
This is a great debate. I need to think about this a bit more, I'm not sold that mark room entitles you to sail off the course. I could buy that the inside boat can slow down but not tack within the reasonable space considered as mark room, but I don't think they can continue on past the mark room space, and expect to be able to keep the leeward boat from tacking. At some point, mark room ends, and the leeward boat can head the windward to up beyond head to wind.
As I understand it, the windward boat would have fouled by taking too much as mark room. This might be the crux of our disagreement.
Mike
Posted : September 10, 2014 11:20 am
(@stank)
One Star Admiral Registered
That's kind of what I was thinking, too, Mike.
Am I to presume you might be able to sail all the way to the other end of the 2-boat circle?
Posted : September 10, 2014 11:25 am
(@brucat)
Case 103 really helps. It's a good discussion about how a jury is to decide how much mark room is appropriate. There are lots of factors to consider.
Eric, regarding Case 15 here, I continue to respectfully disagree that it applies to the original case of this thread. Even the abstract in the front of the book tells you that Case 15 is ultimately about Rule 13.
BTW, for any of you new to racing or serving on a jury, please view this debate as normal and healthy. This is why we have multiple judges and closed deliberations, it ultimately results in better decisions.
Hope this helps.
Mike
Posted : September 10, 2014 11:56 am
(@isotope42)
Originally Posted by brucat
I'm not sold that mark room entitles you to sail off the course. ... I don't think they can continue on past the mark room space, and expect to be able to keep the leeward boat from tacking. At some point, mark room ends, and the leeward boat can head the windward to up beyond head to wind
Let's back up a bit. The definitions do not impose obligations on a boat - the numbered rules do that. The definitions are simply explanations of what the terms used specifically mean. A boat cannot break the rule
mark-room
, and the definition itself does not impose restrictions on a boat's actions.
Rule 18 imposes the obligation on one boat to give another boat mark-room. Rule 18.4 also restricts an inside overlapped right-of-way from sailing beyond her proper course before gybing. There is no corollary rule about tacking.
Mark-room
does not entitle a boat to sail off the course, but it does not prohibit a boat from doing so either. It is not
mark-room
that prevents a boat to leeward (or ahead) from tacking, it is rule 13. Once that boat passes head-to-wind, she must keep clear of the other boat. If she can't keep clear, then she can't tack. She may turn head-to-wind, but not beyond.
No rule restricts a boat from sailing beyond her proper course before tacking, whether at or away from a mark. A boat in a controlling position may drive another boat beyond the mark, out of the zone, and all the way to the edge of the racecourse to gain a tactical advantage.
I hope that helps,
Eric
Posted : September 10, 2014 12:14 pm
(@stank)
Hope this helps.
Mike
+1 This is a great discussion and your input is a valued part of the debate
Posted : September 10, 2014 12:15 pm
(@isotope42)
No, it applies to my previous statement
I'll go you one further and say that even if you AREN'T entitled to mark-room from (and in fact, even if you owe mark-room to) an outside/leeward boat, you CAN drive her beyond the mark. She can take you head-to-wind, but you are not obligated to tack, nor to give her room to tack.
I don't have an ISAF Case citation that is an exact match to the scenario posted, but then again, the boat entitled to mark-room tacked when she reached the layline. She didn't push the leeward boat away from the mark.
You asserted that a boat entitled to mark-room must tack within that mark-room, which is what we're discussing now. I asked you to justify that statement with a rule reference. Cases about how much room is enough, and how to interpret the term
seamanlike
are not germane.
Can you identify any rule, case, or appeal that states a boat is ever
obligated to tack and round the mark
Sincerely,
Eric
Posted : September 10, 2014 12:57 pm
(@brucat)
I think we're getting closer. I still see the definition of mark room as being restrictive: the inside boat is entitled to room to round the mark, not room to sail to Canada then come back and round the mark.
I've searched the case book, and wonder if there isn't a case cited simply because once outside of the reasonable space defined as mark-room, the inside (windward) boat would be breaking other Part 2 rules if she didn't headup when luffed, etc.
Put it this way, if I'm outside and leeward, you're inside and windward, the seas are flat, the breeze is moderate and no one else is around. As soon as you pass the lay line, I'm heading you up to tack. I'll follow the rules and keep clear while turning, but what rules are going to be on your side if you don't respond?
BTW spectators, Eric, Matt and I typically agree on most of these...
Mike
Posted : September 10, 2014 1:14 pm
(@isotope42)
As I said previously, the leeward boat (L) may turn head-to-wind, provided she complies with rules 16.1, 17 and 18.2(b). The windward boat (W) must, in accordance with rule 11, head up to keep clear. If, however, L passes head-to-wind, then she must keep clear and rule 15 does not protect her. W need not turn past head-to-wind.
Mark-room or no mark-room, W is not obligated to tack.
Posted : September 10, 2014 1:38 pm
(@brucat)
Looking back, the only place above that I mentioned
obligated to tack
was in reference to taking too much room to tack due to issues on the boat. Without calling up the reference at the time, my point in that post was to point out the principles of room and seamanlike actions, as expressed in Case 103.
I will agree that
obligated to tack
doesn't appear in the rules, but stick to the interpretation that mark room does not give a boat ROW, and is limited per the definitions.
Mike
Posted : September 10, 2014 1:41 pm
(@isotope42)
obligated to tack
I will agree that
obligated to tack
Of course, Rule 18 does not change which boat has right-of-way (although it used to). My entire purpose for starting this thread was to encourage people to view the rules in terms of obligations rather than rights.
When Rule 18 obligates a boat to give another boat mark-room, it does not, nor does the definition of
mark-room
impose any additional obligations on the boat entitled to mark-room.
Mark-room
is a burden placed solely on one boat.
A boat entitled to mark-room may freely sail outside of that mark-room without breaking any rule. She simply is not protected by rule 21 if she does so.
In previous posts, you said:
  1. In both cases, you are obligated to tack and round the mark
  2. If you're entitled to mark-room over an outside/leeward boat, you can't sail away from the mark just for strategic reasons
  3. it's the inside boat that is entitled to mark room, and is therefore limited per the definition of mark room
  4. I could buy that the inside boat can slow down but not tack within the reasonable space considered as mark room, but I don't think they can continue on past the mark room space
    , and
  5. At some point, mark room ends, and the leeward boat can head the windward to up beyond head to wind
If you aren't arguing that W is obligated to tack, what are you arguing for?
Posted : September 10, 2014 2:11 pm
(@brucat)
My argument is pretty simple.
In terms of obligations: An outside boat is not obligated to allow an inside boat to sail her off the course. Nothing said here by you or Matt has convinced me otherwise.
I will agree that unless L luffs to force the tack (and keeps clear, etc.), they can sail away and W isn't
obligated to tack.
But, L is not obligated to allow this to happen once the point of reasonable mark room has passed.
Mike
EDIT: In my head, this is simple. Thanks for pushing me to clarify here.
Posted : September 10, 2014 2:43 pm
(@pm)
Kinda like what Jimmy did to Deano last year at Mark 1, then the next race Deano did to Jimmy.
I can remember at N20 Nationals in Pensacola several years back Boog driving Alex/Nigel all the way to a pier on the shore. Nigel was soooo pissed.
Posted : September 10, 2014 3:29 pm
(@isotope42)
obligated to tack.
Mike,
That might seem right to you, but it simply isn't what the rulebook says.
Sorry,
Eric
US SAILING Certified Judge
Chair, SAYRA Appeals Committee
Posted : September 10, 2014 4:09 pm
(@brucat)
I disagree. I'll try to come up with a diagram.
What rule would keep L from doing exactly what I describe above?
Mike
Posted : September 10, 2014 4:20 pm
(@mbounds)
13
The leeward boat cannot
force
another boat to tack. If I'm the weather boat, I'm not going above head to wind. If I keep clear until you are head to wind, I've satisfied the requirements of rule 11. If there is contact after that, then you've gone past head to wind (and thus subject to 13) - and you're out.
Posted : September 10, 2014 4:45 pm
(@brucat)
No, Rule 13 restricts tacking. I'm saying that under rule 11 and 16.1, L can luff W such that W has to tack to keep clear, then L can tack and sail to the mark. I contend that per the definition of mark room and Cases 21 and 103, mark room is a finite (condition-based) entity, and L is free to perform this maneuver as soon as W has passed that point.
I'm not talking about any contact, so let's keep that off the table.
Mike
Posted : September 10, 2014 5:14 pm
(@isotope42)
I've been looking for that all day. I thought there was a more descriptive rule about luffing rights, and was pretty sure that if L can luff hard enough (while keeping clear and not passing head to wind), and W has to tack to keep clear, L didn't foul. I couldn't find it in the cases or appeals, either.
You can't find it in the rules, cases, or appeals because it doesn't exist.
Luffing rights
is a term that, like
mast abeam
has been obsolete for over 15 years.
Quote
But, at least we're moving away from the mark room defense here?
I don't know - are you?
Mike, surely with your background in match race umpiring you must be well aware that one boat can sometimes control another -- even if the other boat has right-of-way. A boat behind and to weather, or a boat overlapped to windward can prevent the other boat from tacking. That is a fundamental part of pre-start maneuvering in match racing (and this is one instance where the match racing and fleet racing rules coincide).
As said several times already, this is about rule 13. Mark-room has nothing to do with it. Mark-room imposes no special obligation to tack, nor gives any special exemptions from the obligations of rule 13.
Read rule 18.1(a), 18.2(b), 18.2(c), the definition of mark-room, and rules 11, 12, and 13 again. Then take another look at ISAF Case 15. You'll see that the windward boat can prevent the leeward boat's tack because of rule 13. It doesn't matter if L has right-of-way due to rule 12 or rule 11. If the boats were overlapped, the outcome would be unchanged. You should also see that rule 18 and mark-room have no bearing on the matter. It doesn't matter which boat owes the other one mark-room (or indeed, if neither one does). It's simply the case that L cannot pass head-to-wind and keep clear of W as required by rule 13.
You're reading more into
mark-room
than exists in the rules.
Eric
Posted : September 10, 2014 5:55 pm
(@isotope42)
I'm saying that under rule 11 and 16.1, L can luff W such that W has to tack to keep clear...
If L turns head-to-wind (but not beyond) in such a manner that W cannot keep clear by also turning head-to-wind (but not beyond) in a seamanlike way, then L breaks rule 16.1.
Provided she complies with RRS 18.2(b), RRS 17 (if applicable) and RRS 16.1, L may turn head-to-wind. W must respond and keep clear per RRS 11 (or 12, whichever is applicable), but W is not under any obligation to tack, and L cannot compel her to.
I think we've beaten this topic to death, and I'm certainly tired of repeating myself so please, if you still think that a boat is required to tack at a mark, quote the rule that says so.
Eric
Posted : September 10, 2014 6:13 pm
(@brucat)
I'm really just having an issue with the idea that you and Matt stated that mark room entitles a windward boat to travel well off the course.
Mike
Posted : September 10, 2014 6:38 pm
(@isotope42)
Well then you need to go back and reread our posts. We've both said from the beginning that mark-room has nothing to do with it - just rule 13. It isn't about
entitlement
, it's about
obligations
And, for (at least) the seventh time, please quote the rule that prohibits a windward boat from doing so. When I refer to an obligation under the rules, I cite the rule number and, if necessary, quote the rule text. Now it's your turn.
I'll give you a hint. The only rule that requires a boat to tack is RRS 20.2(d), and it has nothing at all to do with the scenario presented here.
Posted : September 10, 2014 7:01 pm
(@brucat)
Already did that...
...I'm saying that under rule 11 and 16.1, L can luff W such that W has to tack to keep clear, then L can tack and sail to the mark. I contend that per the definition of mark room and Cases 21 and 103, mark room is a finite (condition-based) entity, and L is free to perform this maneuver as soon as W has passed that point.
Mike
I admitted a few posts back that
obligated to tack
wasn't correct.
Mike
Posted : September 10, 2014 7:14 pm
(@pm)
I live diagram would go a long way here. I understand this, but I can imagine where it can be confusing when reading the whole thread. Let me ask this a different way and maybe Mike sees it from a different perspective.
Rule 13 states
During that time rules 10, 11 and 12 do not apply.
also that
If two boats are subject to this rule at the same time, the one on the other’s port side or the one astern shall keep clear.
So when does Rule 11 and 12 reapply?
Posted : September 10, 2014 7:21 pm
(@isotope42)
When one or both boats reach a close-hauled course.
Posted : September 10, 2014 7:32 pm
(@brucat)
Let's ask it a different way: when does 13 apply?
I contend that L can luff to the moon, without tacking, while keeping clear. The only rules that apply are 11 and 16.1. 13 doesn't apply until L crosses head-to-wind, correct? If that's true, L can luff, W would likely tack away, then L can tack and follow.
This all started as a discussion about mark-room. L can't do the above maneuver while she owes mark-room to W. However, that is a finite area, and L is free to luff as soon as W passes the point where luffing would put W into the mark or prevent W from tacking to round the mark as the inside boat.
Mike
Posted : September 10, 2014 7:43 pm
(@brucat)
OK, I've re-read this. I think we're saying the same thing for the case at hand. Other than my incorrect statement about
obligated to tack
which seems to have derailed into the Case 15 /Rule 13 issue, which does not apply to the original case in this thread in any way.
BTW, I'm posting this as I pack the RV for a regatta this weekend (Roton Point). Hope you all get a chance to be on the water this weekend!
Mike
Posted : September 10, 2014 8:10 pm
(@isotope42)
Mike,
It sounds like we're in violent agreement after all. Good luck at Roton Point.
Eric
Posted : September 11, 2014 7:38 am
(@brucat)
Two minutes in person with boat models, and I'm sure we would have been there days ago...
Mike
Posted : September 11, 2014 8:51 am
(@stank)
and both of the boats in question would lose out to the fleet which parades to the mark while they're forcing the issue on each other <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Great if you're trying to pin a boat to secure an overall points lead. Sucks if you're doing it just to prove a point.
Great if you're in a serious fleet (semi-pro or pro) for big prize
Sucks if your a weekender taking things waaay too seriously
But, thanks to this discussion I've spent more time with the RRS than I had in the past year...
it's like sitting in a protest room.... without having to endure the protest room.
And no one called anyone else a profanity...
Posted : September 11, 2014 9:34 am
(@brucat)
Don't forget the case books and appeals! Those books are priceless to round out your knowledge of the rules, you can also learn some good plays from them. It also helps a lot if you can employ a case/appeal during a protest.
You're absolutely right about the practicality of some of these tactics, which was a thought running through my mind during the entire discussion, but doesn't change the rules or obligations. Even if a boat in a controlling position is being penny wise and pound foolish (losing the fleet), you need to know what to do to avoid fouling her.
And, Matt's probably been in the last-race, match-race within a fleet race position more than most folks here.
Mike
Posted : September 11, 2014 9:43 am
Page 2 / 4
