Rotomolded Future
Is there a market in the USA for a rotomolded boat with a little more kick than the Getaway? Getaway is rated slightly faster than a H14 (as is the Dart 16). Something in the H16 range of speed. Since I'm wishing here, 14 to 17 foot, obviously boardless with a square top, high aspect ratio main, self tacking jib, optional double trapeze, optional spinnaker (G-Cat-esque).
Does this defeat the purpose of the rotomolded cat, or not, making it too hard for a novice to handle? Does the increased speed make it, comparitively speaking, a
dangerous
boat? Can enough bouyancy be built in to the bows to avoid pitchpole and keep the speed?
What US builder would potentially step up? NACRA? Vectorworks?
Selling like hotcakes
<img src=
Is it Bob? Or is it progress? Old fiberglass boats are prone to delamination and generally don't look to whippy unless well taken care of. Sure, they can be fixed up with time and effort. Is that what we shall expect from an entry level cat sailor we're trying to woo into racing?
The Getaway looks...like another sailboat, a recreational boat. Why not a specifically designed sporty, entry level, potential racer that is quote indestructable. With new rigging, lines, sails they could feed a novice fleet forever, And feed the high performance fiberglass market.
You all remember when the Wave came out? The hard core racers thought it was a joke, but soon Rick brought a bunch of them down to his place for the
Wave Nationals
and voila, a new racing class was born. That's all it takes. It doesn't have to be a state of the art design, just get a bunch of them together and race. I would think a larger, two man or two woman or two kid, double trap 16 foot Wave with a self tacking jib, no boards, etc, would work as both a recreational boat and a racer. Like the Dart 16. You could even put the Hobie Bob on the mast. I would think the Motels would love it and could even sponsor regattas. I think the trapeze is necessary to get racers to buy into it, maybe offer a spin. kit as well.
How much is that new French cat, the 16'
Youth Worlds
boat going to cost when Performance starts selling them? Anyone know?
Just my two cents here. Getaways are total pigs, but I love them nonetheless. This is why: I don't own a boat. However, thanks in part to the popularity of rotomolded boats I can go to pretty much any beach and rent a cat. I think that's why they're selling like hotcakes: rental. Fiberglass boats are expensive and a pain in the butt to take care of. You can beat the crap out of a roto and leave some 16-year-old to take care of it, and it will last for at least 5 years. So, I don't think people are buying these things for themselves, I think they are buying them to rent to me when I visit Miami. I have what passes for a state-of-the-art rotomolded ocean kayak, and believe me, rotomolding has a long way to go before fiberglass becomes redundant.
I think it would be a bas butt weakend warrior.
The Dart hulls and boat overall
look
much sportier
![[Linked Image]](http://www.hobiecat.com/sailing/images/all_models/2006_colors/getaway_spirit.jpg)
There are pros and some substantial cons to rotomolded construction that you may not have considered. Yes, you can throw a rock at it or play bumper boats and not worry too much - but when you have holed it, you have a big problem. When your keel wears after the 100th time you slide it up the beach, you have an issue. The problem is that repairs of this nature on poly boats are very difficult if not impossible. You're not going to fiberglass it together and the
poly-welding
that used to be possible on them is not anymore. The the new cross linked polyethylene materials they are using to build these boats today are superbly tough but do not lend themselves to heat welding or other means of repair once the plastic is solidified. So yes, they are more durable but they are less repairable. Poly constructed boats are great for businesses that intend to depreciate and eventually trash the asset after several years. I wouldn't recommend it to a sailor that intended to use it at a high frequency for a lengthy period.
The tooling for producing a rotomolded object can more expensive as well but pays for itself through high iterations of production - so not suited for small runs.
By contrast, if you wear out the keel on a fiberglass boat, it's ready to go again after few hours in the garage.
The Wave class is a terrific racing class with very tight and very even competition. I think the Wave fills a very neat niche in the industry. Personally, I've had some of my most fun moments on one and would certainly have one in my backyard if I thought I had the time to sail it. Fair, even, and exciting racing can certainly be had on any rotomolded sail boat - speed is relative. I just don't think it's going to be the wave of the future (pun not intended).
I agree with Jake except for one area, repair. The cross linked plastics can be repaired, it just takes different tools. I have two, an auto body brazing tool and an industrial(high temp) hot glue gun. Both effectivly braze the plastic.
There are several other ways to repair this type of plastic(involving chemical reactions) but it's DIY, there are no kits available.
Found this regarding windsurfer repair (old BIC? notice the ref. to 1981 price), however it's confusing, not sure whether he's referencing cross link repair or using cross link to repair linear?
HOT AIR WELDING/POLYETHYLENE
We use the hot air welding gun manufactured by Leister Co. and distributed in the United States by the Robert R. White Co. The gun costs $385.00(1981 price). Special tips are required; these cost approximately $80.00 each. The most often used tip is ______ . This tip uses 3/16
extruded high density polyethylene. Also needed are scrapers for cleaning the polyethylene.
The cross-linked polyethylene that we use is known as a thermo-set plastic. This means that once the plastic is heated and melted, it cannot be melted without burning it. You need to use a material that is the same as the skin. ( Therefore, the kind of weld a hot air gun produces is not a true fusion of the plastic (as in metal welding, brazing or aluminum helearcing).
Experience bond and controlling the three variables are needed to produce a successful bond. Three variables are:
1. Cleaning both the polyethylene board and rod with a scraping tool.
2. Controlling the temperature of the tip of the gun at 3OO°C.
3. Drawing the gun across the weld at a steady controlled rate.
DON'TS
1. Do not try and melt the extrusion into the board.
2. Do not hold the gun for too long in one spot. It may bubble and delaminate the hull.
3. Allow the weld to cool completely before testing the repair.
The repair can be finished by shaving the weld flush with the hull with a sure form or sanding.
The hot air welder can be used to repair daggerboard wells, mast-steps, skeg boxes, and replace large hull sections that have been damaged. When replacing hull sections, mast-steps, and daggerboard wells, it is best to cut out the sections with 2-3
deep of foam attached. Bond this to the hull with the epoxy and then seal the perimeter with the hot air welder
You are not going to hot air weld crossliked PE. The plastic molecules have chemically bonded to each other and a hot air gun will not break these bonds, allow more material to be introduced, and reform the bonds. Older PE boats did not have the plastic crosslinked. This is why you can repair them by heat welding.
As mentioned before, crosslinking is a double edged sword... They are very tough and can take enormous amounts of abuse, but once you finally break or wear out the plastic, it's pretty much over.
The crossliking is also why not much sticks to the hulls.
I know nothing about repairing Polyethylene. I do have a repair kit supplied by Laser for the Dart 16. 2 methods of repair are mentioned. One is Rod Welding with a Leister gun as described above by John.
The other is Powder Welding. For this you need a hot plate and frying pan, a heat gun and a putty knife. And of course the powder which is supplied in this kit.
This is heated at 150 C for about 10 mins. The area to be repaired is cleaned and sanded - broken bits cut away etc. The area is heated, the putty knife is heated and the melted plastic is quickly spread onto the area. When cooled smooth with chisel or block plane. Finish by sanding and heat polishing the area. To heat polish: sweep the gun back and forth across the area until it glosses over.
That's what Laser say anyway <img src=
I'm getting sick from the dizziness <img src=
Yes, you can!
NO, you can't!
Check out the lead boat sailing uni...Dermot?
Dart 16's and large, orange floating object
OK, I guess the Laser material is NOT cross linked.
It is Techrothene 109, from the Laser Pico brochure;
Techrothene 109 is a linear high density UV stabilised compound moulded into a stress free homogeneous sandwich with an inner closed cell structure.
Exceptionaly Strong
Incorporates built-in buoyancy
Superbly Stiff
Highly resistant to scratching and impact damage - easy to repair
Yes, you can!
NO, you can't!
Link did not work <img src=
Laser also call their material Techrothene 121 <img src=
http:/
Same Event - This years Nationals. This one is
Dermot
I won that event <img src=
Total 27 cats: 9 Dart 16s, 2 Dart 18s, 1 FX-one. The rest were Spitfires, Tigers and Hurricane 5.9s.
Actually, Hobie did originally use linear polyethylene but I believe they went to the cross linked poly about the same time they started making the hulls thicker (or double walled I think). I believe they made the change to increase the durability of the boat (it also made it heavier).
There are resin systems available now that will repair all the poly products. They tend to be very expensive and many were originally developed for the automobile industry particularly for repairing
thermal
bumpers etc, also as glues for bonding metal panels to metal instead of welding as well as metal to any/all types of
plastic
and of course plastics to other, different plastics.
Thanks Tim.
I know that I am
off topic
, but there are some video clips taken the evening before the event on www.catamaran.ie No. 1 is a good one of Amy Jayne, driving the Spitfire downwind from the wire.
- 6,494 Online
