Screws In Epoxy, Best Way?
Are you talking about a mast?
You'll need to tap it. I would also consider putting a neoprene (the green ones) o-ring under the head of the screw so you won't feel the need to tighten it too much...that o-ring will also help to prevent the screw from backing out with trailer vibration.
I don't have any real data to back it up but the green o-rings seem to resist UV better than the black ones.
I also wouldn't directly tap anything that needed real holding strength into a composite structure...but you're fine in this case with a drain plug.
Jake's over thinking this.
Let the hole dry out. Clean it out with a pipe cleaner wetted with acetone.
Use thickened epoxy (JB Weld works fine for this - hard to measure this small amount of WEST) to fill the hole. Use a toothpick as an applicator and make sure the hole is filled with no air bubbles. Put a piece of tape over the hole to keep the epoxy from oozing out.
Several beverages later, peel off the tape, drill a pilot hole for the screw (no tap unless it's a machine screw) and reassemble with a dab of silicone around the drain plug housing. Don't overtighten the screws.
- 1,335 Online
