Self Tacker Retrofit
If you mean a used F18, then yes I'm spending nearly what I could have got one of those for. On the other hand, used boats tend not to come with spiffy new sails.
But anyway, I'm long past the point of no return on this project.
It may be possible to use the Hurricane 5.9 SX kit from Andy Webb at AW sailboats awsailboats@rya-online.net Telephone +447941 940459 (day) or +441255 554769 (eve)
The boats are pretty similar in size so the track radius could suit (possibly better than the F18). The suitability of the jib however would also depend on the forestay length/angle. The full kit includes jib + track and fittings plus spi pole and fittings over - pole glass snuffer tube and kite. I'm sure that AW would sell bits 'as required'.
Cheshirecatman
Take a close look at your jib, if it's the standard 5.8 jib I'll bet it is way too big for a self tacker. Just rig it and hold the clew at the mast, if it overlaps the mast to the rear, it will have to be recut to work on a self tacker. The jib clew must be shorter than the distance from the tack point to the self tacker track, plus the clew shackle and block.
You should get up close to a Nacra F18 with a tape measurer and check the distance they are have, jib tack to jib self tacker track, then check yours, to about 2
infront of your mast on the main beam.
Most of the earlier (pre Inter 18/20) Nacra's had big footed jibs that overlaped the mast, won't work on a self tacker.
Of course you could just buy the F18 jib as well. <img src=
Of course. I'm having a custom jib made for the boat. I'm keeping the NA foil but going to an original area jib with a longer luff and shorter foot.
Anybody have experiance with this Holt Allen kit? http:/
. . . and to add, the NA is deadly fast downwind when sailed correctly.
Thanks Philip, having to do it over again, I wouldn't have taken the time or money to put the spinnaker on the 5.8 NA - the boat rocks in it's stock configuration w/squaretop
Was it fun to sail -absolutely, did it look cool - Jame Dean had nothing on me, was it worth it - I have a mixed opinion leaning towards
should have put that money towards a boat that was designed to have a spinnaker from the start.
Yeah, the price is outrageous, so I was thinking of copying it with Harken parts. Should be pretty easy to get track bent, and then fab up an attachement to the main beam.
But I'm not averse to paying real money for something if it's worth it.
Is it necessary to have a floppy self tacker (allowed to pivot about the axis of the main beam)? I guess it would help with alignment of the loads, but in light air I can imagine it would pull down on the jib
Opps!!!! Open mouth change foot - I kept forgetting about you guys up there in Santa Cruz - sorry I didn't refer Rhino to one of the only true catamaran dealers left in CA.
- 1,857 Online
