Smiple Questions
9 Users
11.8 K Views
Bruce
(@brobru)
Bill and all,
Ok,.here are some number.
Took them off the Performance site
TOTAL Sail Area ( s.f.)
I17normal ( not R) 160
I18 227
I20 247
As a percentage increase sail area, using the I17 as a basis
I 17 100%
I 18 141% ( main and jib)
I 20 153% ( main and jib)
Correct me if I am wrong, but wasn't the I-18 the first in this family of design?
And all the I series use the same rudders and d-boards.
Therefore, the I-18 has the rudders and boards that came off the designers computer as THE correct configuration.
So, if we now switch the basis to the I-18, for this is the correct design boards/rudders;
I 18 100%
I 17 ( 160/227) x 100 = 70.46 of the size needed, so current I17 rudders/boards are 30% ish too big.
I 18 100%
I 20 ( 246/227) x 100 = 108.37 of the size needed, so the I 20 current rudders/boards are 9%ish too small.
Someone check these ratios and see if these numbers are good.
I will be honest, and as Tom stated also,. the I 17 rudders do not fail.
I also know from a local I20 racer, that the stock I20 rudders do not do the job.....which is probaly why the retro rudder is now available.
....ok, enough of this stuff, lets just go sailing..
Bill, congrats on the RC30 cleaning up in the Caribbean. Tell the owner to come to St. Croix in Feb 2005.
regards,
Bruce
Posted : June 16, 2004 5:15 pm
(@wouter)
eehh Brobu
Didn't we go through all this a while back, including the math etc. Then we came out at 30 % as well.
It may be more efficient to search the thread of back then and read it all over again to see what you have forgotten since then. The answer you are looking for are there already.
Wouter
Posted : June 16, 2004 5:29 pm
Bruce
(@brobru)
Wouter,
ok,....I will quit beating this dead horse..
..I'm off to go sailing.
Bruce
Posted : June 17, 2004 7:12 am
scooby_simon
(@simonJlongstaff)
Quote
Wouter,
Bruce
I've been sailing today ! Good F5-6 plenty of spray, plenty of Kite flying......and my plates were a long way up most of the time......
Posted : June 17, 2004 8:59 am
Page 2 / 2
