Snuffer Spin Attachment: Grommets or Fabric Loops?
What's the general recommendation for attaching a snuffer line to a spinnaker? I've got a spinnaker with no provisions for a snuffer line that I would like to add some to. Obviously the attachment points should be re-inforced but is it better to use grommets or a small nylon webbing loop? I've seen them both ways. Does either help reduce the ball of sail going into the snuffer?
New Tiger spin has grommets with small ss rings attached. Much less reinforcement than earlier chutes. I would think more reinforcement and straps would cause more bunching as the material is thicker in the patch area. Just my opinion but the new ones seem to work fine with no tears so far. I have Bill Hendricks modifying my old spin to this for the mid pole. Rick
Looks like a single layer of extra cloth in an X pattern with a small gremmet in the center. A small line with a small stainless steel ring tied to it is passed through the grommet and fastened with a stopper knot. The retrieval line is then passed thru the SS rings and then dead ended at the top grommet. Much easier to see than describe
- 1,080 Online
