Spinpole Windex Mount
windex?
heh
Magnetic tape on bridles. If you put a windex anywhere, it probably should be on the top of the mast.
If you put it anywhere on the pole, the spin is going to eventually grab it, and rip it right off - or worse, put a hole in yer chute.
Mag tape works wonders!
8 track? What's and 8 track?????? <img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" />
That's those things on the spin bridle you wouldn't look at, at the Tybee last year. <img src="<>/shocked.gif" alt="shocked" title="shocked" height="15" width="15" />
Why does the crew need to look at those? Was he having to drive too? (I gotta stand up for my SF crew).
I was just supposed to let the old guy comment slide right by?
You know me better than that.
Jake,
It's a boat direction spin trim thang, I'll 'splain it to ya sometime.
Too funny.
I use cassette, and old VHF tape. I think some Barney's playhouse video adorns my shrouds.
I do have tape on the bridles, and will keep it there - but I do know quite a few people have them on the pole, and I'm assuming that if there were issues, they would have yanked them.
But...that's why I bought a removable one. 😉
Jake,
Errrrrrrok.
I've created a vane from a 5
spring (Ace Hardware), some plastic celaphane sheet (craft shop), a straw (McDonalds). I cut the plastic into a triangle about 5
long by 1" wide and creased it down the middle to make it stiff. I wrapped the wide end around the straw and stapled it... The straw rotates freely on the spring... I just tape the vane to the end of the spin pole. It works great, but mainly only use it in light air conditions.
I've seen someone else use a cable cover and tell tale, which also works well...
Either of these are soft and flexible enough to not tear your spin.
Bon Jovi and Celine Dion are the fastest tapes out there. I hear Wayne Newton is quick, but I dont have any 1st hand knowledge, I will have to get the 8 track from Tawd.
I did join Columbia House and got a box full of 8 tracks when I was a kid...AC/DC hell's Bells was in that box....
I've been using a
how to quit smoking tape
ever since I started sailing in 2000. I DID quit smoking cigs...but it hasn't helped me on the water...
yuk yuk yuk.....
consequently, while coming back from Keowee two weeks ago, while towing the boat back home, I had that cassette in the front trampoline pocket of my a-cat. The tail apparently snuck out the zipper enclosure and by the time I got home, I had a 50 yard tape streamer off the back of the boat...I think it used up that tape. I'm going to have to find something new....so let's hear it.
Mark's deal with a spring, a straw, and a piece of cellophane works great and is unlikely to snag the kite.
I bet the 5 cars behind you thought you were ... ummmmm,.... well lets just say... ummmmm....
special
<img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Mark,
I'm not clear on the spring part, how does the vane attach/rest on the spring.How do you attach the spring to the boat? Tape,I'd guess.
A pic would be great.
Thanks.
Tawd
- 5,800 Online
![[Linked Image]](http://i703.photobucket.com/albums/ww38/jca2627/Windex.jpg)
