Spray paint graffiti
6 Users
(@Greg Heebner)
Newby Registered
[#30992]
Does anyone know if you can or how to remove spray paint graffiti from a sail without damaging the sail? The graffiti is three plus years old on the bottom section of the mainsail. The sail is in good condition. I'm currently keeping it as a back up.
Posted : February 23, 2016 2:44 pm
Jake Kohl
(@jake)
Is it a dacron or mylar sail? If Mylar, it should be relatively stable against MEK (methyl ethyl ketone) and that MEK is a pretty good solvent and should remove the paint if used carefully.
Posted : February 23, 2016 3:22 pm
(@Greg Heebner)
Newby Registered
It's a Dacron sail Jake. Thanks for your prompt response.
Posted : February 23, 2016 3:59 pm
(@_removed-account)
Four Star Admiral Registered
I have no idea if it is fabric safe but many spray paints (from a can) can be removed with Acetone
Posted : February 23, 2016 4:26 pm
Jake Kohl
(@jake)
Dacron is more difficult. It's essentially a polyester fabric - which isn't great on it's own against a lot of solvents (it is listed as
marginal
resistance against MEK and Acetone...which isn't great). Dacron sail cloth also has several different coatings and binders that might also be affected by solvents. By the book, there probably isn't an easy way to remove the paint from Dacron without some risk of damage to the cloth but maybe someone else has some more practical experience.
Posted : February 23, 2016 5:21 pm
(@_removed-account)
spray new paint the color of the sail over the graffiti ?
Posted : February 23, 2016 6:10 pm
(@catman)
Make sure you use MEK solvent not MEK Peroxide. MEKP is used to catalyze resin, Poly and Vinyl Ester resin.
Posted : February 23, 2016 7:42 pm
(@isotope42)
Try xylene first. It's less volatile than MEK, making it easier to apply. Xylene is also safe on Dacron. That's what I use to remove adhesive left over from old insignia cloth. It also works great for cleaning tar off your feet (if you launch off the beach on the Atlantic coast).
I hope that helps,
Eric
Posted : February 23, 2016 9:11 pm
Jake Kohl
(@jake)
Eric, great catch! I looked that up in the tables and Xylene does have a good compatibility with Dacron.
Where on the Atlantic coast are you getting tar balls? You should try Long Beach!
Posted : February 24, 2016 7:33 am
(@stank)
One Star Admiral Registered
Pretty much anywhere near commercial shipping. They ballast their hulls with seawater (which invariably seems to have oil or bunker residue) and pump out near the docks.
Used to get them a lot up and down FL east coast. Baby oil was a good to get that stuff off your feet.
Posted : February 24, 2016 9:58 am
