sticking daggerboard on H20
(@Anonymous 117)
[#9426]
One of my daggerboards is difficult to lower and raise on my 1998 H20. The top of the daggerboard trunk has a velcro-like material that causes friction. Do I have to replace this, or is there an easier solution?
Paul
H20 #714
Posted : December 1, 2001 1:14 pm
(@stilettodude)
Paul, Sight down the length of the daggerboard. It may have a bow in it. I've seen it happen before. Try switching the boards in opposite slots. If the problem follows that is probably it.
Clayton
Posted : December 1, 2001 10:30 pm
Rafael Quesada
(@rquesada)
I have a 1993 H-20 and had the same problem with the daggerboards; it was a real workout to pull or push them; the solution is very simple; once a month or so, spray a thing coat of silicone on each side of the boards and they will work
like a violin
Do not touch or remove the piece of carpet you have in the trunk of the boards or you will regret it and the boards will be really loose and the water will push them up when you are sailing.
Good luck
Rafael
H-20 / CABB
Miami
Posted : December 4, 2001 2:12 pm
(@Anonymous 117)
Thanks a lot for the tip! What type of silicone do you buy? Is if for waterproofing shoes?
Paul
Posted : December 4, 2001 2:41 pm
