String sucking beam
(@mookie)
[#31010]
I'm trying to get a new-to-me Taipan 4.9 back up to snuff, and I was wondering how to run the down haul and rotator lines. There are mentions of them being led or sucked into the front beam, but I can't figure it out. There are openings in the beam, so that's easy, but is there any tensioning? How do you rig that? Thanks in advance.
Posted : March 21, 2016 1:38 pm
(@edgarapoe)
Had one, but forgot
Rick
Posted : March 21, 2016 2:07 pm
(@rehmbo)
Check page 47 here for a diagram of the C2 cunningham/downhaul takeup:
http://www.goodalldesign.com.au/Catamaran/index.php/owners-corner/documentation/15-c2-manual
Jib sheet takeup is a bit simpler but I couldn't find a drawing. Attempting to describe here:
For Starboard jib sheet, bungie starts at stbd end-cap, goes inside beam to a block on port side, then returns inside beam to stbd side where it is attached to the stbd sheet. Unstretched bungie is usually a bit more than beam length. You may have to adjust length to get the right tension. I found it is easier to attached the bungie to the sheet on the port side and then pull it through as needed.
Reverse for port side sheet.
btw - not all bungie is created equal - don't ask me how I know <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" /> . Go for the good stuff
http://www.apsltd.com/covered-solid-elastomer-stretch-cord.html
I don't have any special takeup for the rotation control. Just looped around the side-stay and terminated at the tramp.
Posted : March 22, 2016 4:16 am
(@mookie)
Thanks for the heads up on the shock chord, I had no idea. To me, this boat is like a big puzzle. Fast, but a lot to figure out, and I really appreciate the rigging info.
Posted : March 22, 2016 4:44 pm
(@rehmbo)
Don't be afraid to do some google searches too.
http://www.geocities.ws/f16hpclass/ahpc_taipan_49_how_to_rig.html
This forum has some old threads that would be helpful too. Like this one: http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=22327
Looks like there is a wealth of information out there. Good luck!
Posted : March 22, 2016 5:06 pm
