Tell me about the Prindle 19
23 Users
127.7 K Views
Jake Kohl
(@jake)
Originally Posted by Team_Cat_Fever
Originally Posted by JeffS
I've removed a top deck before on another boat and it turned into a big job to get it tidy again. I would encourage you to do it through the side as the above posts by experienced people recommend. The more worried about your fibreglass skills the more you should go through the inside of the hull, even if you don't do a very good paint job on your repair nobody will notice it but your decks everyone will see. If you do manage to buy a new deck you need to trust your resin skills to glue it down with absolutely no gaps anywhere or it will suck water and it is very difficult to stop these leaks afterwards
I've done both and getting the deck off without tearing or breaking it is very hard (Apparently too hard for me) if you are going to try and get the deck off you need to use a heat gun and a putty knife ,but not get the glass too hot. The side is easier, will finish better (especially if you do the pumpkin cut) and is less apt to be under as high stress loads as the deck will be. Just make sure you have open access before you cut i.e. not cutting into a bulkhead.
Aaaa! good point...avoid bulkheads. Cutting into one of those for your access hole has a suck factor of
12
Posted : October 16, 2012 6:58 am
(@Anonymous 39709)
I agree with cutting into the sides vs. removing a deck. I need to cut into the sied of my N20 this winter and have been studying Jakes repair photos for ideas. Not to hi jack but has anyone ever noticed a thin, soft line in the side just below the no-skid where your heel rides when trapping out?
Posted : October 16, 2012 10:23 am
Jake Kohl
(@jake)
I've never noticed that on any of the 20's I've owned/worked on. Is it horizontal? There shouldn't be any structural feature to cause that (unless you have a Hobie Tiger-like sub deck for some reason).
Posted : October 16, 2012 12:58 pm
(@Anonymous 39709)
It is horizontal and about 16" long. I'm thinking there may be a seam in the foam core here. I'll be cutting in a hole on the inside and likely laying up some carbon in there.
Posted : October 17, 2012 11:23 am
(@azcat)
Mine had a 6
fracture when I bought it,. I chased it , glassed it and gelcoated it, seems to be solid so far. It was right behind the rear beam, 6
down.. It was easy to sand and add a layer of glass on the inside through the access port. I got lucky. There was no structural member there.
My 5.0 had a 6" fracture in front of the main beam. right at the top of the long. struct member. same fix. single layer glass hulls so I just fixed from the outside.
Posted : October 17, 2012 8:45 pm
Page 4 / 4
