The popping of rivets using the "power pole"
General Sailing Forum
1
Posts
1
Users
0
Reactions
519
Views
The first time I used it (the pole) besides being trapped under the high dagger, I pulled out the two rivets under the base plate. After further investigatgion, I found the primary reason: If one takes the pole to far forward, and the pole bottoms out against the striker, it creates a gigantic fulcrum againt the base plate, and rivets cant take that kind of load. I have since used the pole, being cautious of placement, and it has not been a problem....
Hope this helps, by the way, I am 6'4" 200 lbs and can solo right an I-20...
Posted : September 6, 2002 10:21 am
Forum Information
- 1,331 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
