tornados tillers off the back???
as decent video of the last cat racing in the olympics seems non-existent for most of us i went back to watch the most recent
best tornado video
, the 2008 takapuna worlds, http:/
i notice at 31sec、 2.21sec、3.08sec, 3.48sec, 4.27sec, 5.32sec、and 7.04sec that when going downwind on spinnaker that the crew? is as far aft on the wire as possible and the helm? on the tramp and steering with the rudder cross bar, the extension has just been bailed out behind the boat and is bouncing along in the wake
just a few noob guesses here but i suppose this means
1. that with the crew so far aft there really is nowhere else to put the rudder extension
2. that this is something only done when the wind is strong enough to support 1 hull up with both still 2 on the windward side of the boat
3. that tornados don't use extending tiller extensions, just fixed length carbon tubes
is that right???
As a duly designated member of the Crew Union, I can say that the crew never
bumps
the tiller extension. Some skippers have a tendency to smack and poke their crew with the tiller, however. This is generally presumed to be accidental. <img src=
bumps
I believe skippers refer to this as a
Gerk
(or
Gurk
) designed to remind the crew to pay attention to the sails?
This technique appears especially effective when 'demonstrated' on certain sensitive areas of said cremember's anatomy.
Gerk
(or
Gurk
It is, indeed, known as a Gurk. That is the sound the crew often makes when this
method
is employed. Crews do not appreciate getting gurked, and some skippers are forced to move to single-hand fleets once they are labeled by the Union as a gurker. Although I once knew an F17 driver who gurked himself.
Actually most T sailors use telescoping tillers and you can use the tiller downwind if you want. However, there are couple of benefits to using the crossbar:
1) The skipper can plant his arm down and hold the rudders more steady against the waves.
2) By laying down the skipper can see better from under the main.
With the crew that far aft, the tiller is clear of the crew generally, but a good reason to toss the extension is to avoid the crew from breaking it in multiple pieces when he slips and bangs against the hull.
Most, but not all teams use the Marstrom telescoping tiller...runs over $500 USD before shipping. Nice, light, very fragile.
When mine was broken into 3 sections, I replaced with an 8' A-cat carbon extention.
Another technique I see T helms use is to place the extension on top of the shoulder and grasp it from below. Have only tried it once or twice but could not get used to the weird feel. I leave it under my arm & tuck it under my armpit whe I need a second hand...I find I can steer a little just by leaning my upper body in or out.
Mike.
Practice and perfect this technique. Using the tiller overhand means you hinge at the elbow, underhand you have to use the shoulder. Hinging at the elbow is far more accurate and uses less energy.
On my last two boats (A cat and Tiger) I was able to rest the tiller on my shoulder to sheet with both hands. Unless your helm is way out of wack there should be enough friction against your shoulder to keep the boat going straight.
after initially trapping with he extension underhand i've now swapped to doing it overhand and resting it on my shoulder when sitting on the hull, it does seem more comfortable but you need a well fitting pfd
when first doing it and wearing my old loose fitting lifejacket, that rodes up, a couple of times when i came in off the wire and thought i was resting the extension on my shoulder it had actually threaded itself through the arm opening of the pfd and i hadn't noticed
until i trid to scoot under the boom and found i couldn't swing the extension behind the traveller
made for an interesting few secs as i fumbled around putting the boat into wind to take the jacket off and unthread it.
pic attached shows how close extension end is to shoulder opening when out on the wire and overhanding it
I'd be scared to pull too hard on those carbon marstrom tiller arms.
In the case of a stuff, I know a couple of UPPER end skippers who basically wedge themselves in by putting their forward hand into the lacing just in front of them.
That is fabulous, athletic, fast, beautiful stuff.
I enjoy skiffs but they are so over engineered and complicated in comparison.
As long as the Olympics omit cats, they are out of date and second best.
It is very sad to think the T would be gone as it represents the fastest beach type sailing of the last 40 years and it is still a classic thing of rare beauty.
I was watching a little video of the big tri the other day and the same thing raised it's head. Why would you bother trying to drag all of that bulb through the water when you just don't have to?
I am left with a strong line of thought which is
thank God my neighbour wanted to get rid of his PT all those years ago
- 2,802 Online
