What do you do when your bow stuffs?
When sailing downwind with your spinnaker and your bow stuffs hard, like up to crossbeam, presuming your crew is locked in on the wire... what should be done with the spinnaker... should it be blown to reduce momentum? OR held tight to hopefully lift the bows? OR is it too late to do anything and just cross your fingers?
We've tried the first two and found about the same success rate but i'm leaning towards the idea of staying trimmed in... any other methods? How about trimming the spinnaker in to reduce flow but still keep generating lift?
Skipper to crew:
why did you quit trimming?
I usually go straight to the Swim option, like the Marines say when they enter a bar on Shore Leave,
Go Ugly Early, avoid the rush...
I look for a soft spot to land so I don't break anything and then I can get busy snuffing the spin to right the boat...I'm getting pretty quick at it really.
Ask Seth:
http:/
Who's on that boat in the background applauding...?
http:/
It looks like dropping the traveler would work. Finding the time might be a problem.
Correct me if I'm wrong, but won't dropping the traveler only make the situation worse????? When the bows stuff, the boat stops and the aparent wind moves WAAAAY aft. Dropping the traveler will now expose more sail area to the new apparent wind making a bad situation worse. I've always dealt with it by keeping weight back (as soon as bodies start going forward, it's all over), driving down (assuming rudders are still in the water), and praying!
Drive better.
Oh the shame of it all getting rolled by the Todd's on the same day how will I get on with my life. Refresh my memory, where did you guys end up that weekend? And don't be a little bitch and whine about the redress.
I told you all ready, I don't pick on you anymore and I'm truly offended that you lump me into the same category as
The Punk
. It's not my fault his mom named him after me, then he fell horribly short of that benchmark. I think I deserve an apology from you and his parents.
that boat was going over no matter what. when someone is in front of the forestay the game is over and if you are the one still at the back of the boat pick your exit strategy.
Unless clipped into a chicken line I would think it would be pretty impossible to trim in the spin when you stuff it because all your effort is in not flying forward when the boat slows down so much and by trimming the spin in you will be pulling yourself further forward.
Timbo- on a blade when you stuff you are toast- especially if you are solo and can't drop the trav- very unlikely to come back from that. The N20 is more forgiving and when you stuff you can save it especially if you've got a fat bastard at the back of the boat.
now, that is impressive... however, one would think, even still, that that was much more luck than skill <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
- 3,979 Online
