what to wear under drysuit
birthday suit. be careful with the zipper - it's a duzy.
I was once told to dress under the drysuit in the fashion that would keep you warm on shore. That rule of thumb worked back when I used to wear a drysuit. Definitely wicking and layers. It's only supposed to be in the 60s this weekend here so northerners should find it balmy.
I usually only wear one wicking under layer. A dry suit with nothing under it will kill you when you fall into the water (due to its enormous thermal conductivity). In that case its much safer to wear a wetsuit.
When it gets down to around 10-15 degrees celcius (50-60F) I usually pop on a moderately tight fleece sweater (too loose and the inevitable folds get in the way).
Dennis
PS: there's lots of dry-suit weather here in the Netherlands...
- 1,800 Online
![[Linked Image]](http://www.tlitzen.com/res/1/000000020906_r_xmc2004-e.jpg)
