Where to get a custom carbon mast?
16 Users
22.8 K Views
(@_removed-account)
Four Star Admiral Registered
[#22222]
Hi All,
Yesterday as i was stepping down my 30', 3 ton Mystere 5.5 mast, and my friend was stepping his 31' mast (Mystere 5.5 ) he said, “I am to old for this *#*&!, I need a carbon fiber mast”....
Not that i can afford one (I am sure) but i am curious where one would get a custom carbon fiber mast made, and does anyone have any idea what one would cost (ball park)?
Thanks, Andrew
Posted : March 24, 2008 10:18 am
(@mikekrantz)
Forte or Hall spars are a start, probably between $5k and $6k.
Posted : March 24, 2008 10:22 am
bvining
(@bvining)
Second on the Forte, or Hall.
I have a repaired carbon i20 mast, you want to buy it? PM me.
Posted : March 24, 2008 12:24 pm
(@Anonymous 39832)
Rumor has it that the I20 is going to an alum mast same as the F17's.
Posted : March 24, 2008 1:25 pm
Jake Kohl
(@jake)
Quote
Probably worthy of another thread - but we're at a cross roads as a class. If the boat prices stay as high as they are (over $20k due largely to the carbon stick), new boats simply won't sell and the class prognosis is eventually terminal. If the price can be made lower with an Aluminum mast AND it could be made as competitive as the carbon stick then new boats will sell and although the class could be damaged by the addition of a carbon mast, it won't necessarily have a terminal outlook.
Posted : March 24, 2008 3:17 pm
(@Anonymous 39832)
I just remember stepping the 68 lbs Nacra 6.0 mast.
Dreadful.
Posted : March 24, 2008 3:24 pm
(@_removed-account)
what really got me was when my spin halyard got caught on my trailer and i twisted my back... it is a killer!
Posted : March 24, 2008 3:49 pm
Jake Kohl
(@jake)
Quote
Or your trap ring gets stuck in a daggerboard trunk.
Posted : March 24, 2008 3:59 pm
(@Anonymous 39546)
I'm sure John Pierce from Stealthmarine will quote. Could be cheaper than you think.
Posted : March 24, 2008 4:32 pm
bvining
(@bvining)
I dont quite understand why the i20 mast is so expensive. Last I knew it was over $5k.
I got a quote on a 33' tube from Forte that they are making off the aluminum T section, so its pear shape, for $1400 - thats last years price, but still no where near $5k.
And my Acat mast (29') was $2200, and the Hall stuff is very, very well made, all hand laid, clear coated, wing shape, way better part than the i20 mast, just a little shorter.
I dont get it.
Performance needs to find a new supplier.
Bill
Posted : March 24, 2008 4:42 pm
(@Anonymous 38725)
Who is Perf. using for the I20 carbon stick? If they are using someone out of the US, the weak dollar plus shipping could be part of what is driving up the price.
How much does the
new
aluminum wing mast weigh on the Capricorn? What would the same section weigh at say, 2 feet longer, if that's the difference between the I-20 and F18.
Posted : March 24, 2008 5:05 pm
PTP
 PTP
(@CaptainPP)
Quote
Dreadful.
That thing sucked..... and after that everything seems like a piece of cake. I just always hoped that when the time came, the person I was with hopped on the tramp first.... then I would say...
let me help you and I'll lift the end up and grab the forestay
<img src=
Posted : March 24, 2008 5:14 pm
(@wildtsail308)
The 20 masts are made by Omohundro, a division of Southern Spars, i'm pretty sure the new ones are labeled as Southern Spars. Last price I heard was $5,600
From what i've heard the masts are produced in South Africa then shipped to CA for finishing. Explains the high cost when the money spent in fuel is considered.
Personally, I think the 20's mast is way overweight... the gelcoat covering certainly doesn't help! The 18HT and Tornado masts are similar lengths and much lighter! Neither have the gelcoat... does the gelcoat make that much of a difference in durability? If so why don't other carbon masts have more protection? Is clearcoat lighter?
The Capricorn mast is extremely light, I was shocked when I chartered one last year and went to raise the mast. I might even go as far as to say its not any heavier than the 20's mast (I realize it is a couple feet shorter). I've heard the infusion mast is light as well, if the class went to that extrusion, I don't think the weight difference would be that dramatic. I feel that the change to a wing mast would be more of a difference.
If your looking for a lighter mast, i'd talk to Robbie and Jill, they are in your back yard and could supply you with a Capricorn extrusion for a lot cheaper than you getting a custom carbon spar made.
Posted : March 24, 2008 7:37 pm
(@Fasterdamnit)
Quote
You guys ever consider a winch on the trailer upright? Makes it a much easier job.
Posted : March 24, 2008 7:41 pm
(@Anonymous 2286)
Quote
Quote
And a ginpole makes it even easier.
Here's an old thread to explain.
http://www.catsailor.com/forums/showflat...&PHPSESSID=
Posted : March 24, 2008 7:52 pm
Jake Kohl
(@jake)
Quote
I dont get it.
Bill
Boy, with those figures on the table, that sure doesn't make sense does it?
The N20 mast is pretty heavy for a carbon stick and it's not terribly stiff - BUT one could argue that it is pretty darn durable. I've only seen a few break and most of those reasons were pretty obviously not the mast's fault (flipping in the surf).
Posted : March 24, 2008 8:18 pm
(@davea)
Southern Spars make the masts. They are located in New Zealand.
Posted : March 24, 2008 8:59 pm
Jake Kohl
(@jake)
Quote
And I'm sure the US Dollar exchange rate isn't helping things at all.
Posted : March 24, 2008 9:10 pm
(@basketcase)
http://www.csi-composites.com/
i worked on an open 60 rig in this shop. great bunch of guys. best products. ive got their stuff on my boat.
Posted : March 24, 2008 9:53 pm
(@jeremyleonard)
Your best bet is definitely going with a domestic source. Call up Ben Hall and see if you can get set up. Shipping a single carbon mast anywhere right now is a killer, and going to get worse here pretty quick with $4 Diesel.
Another option is to call Fiberfoam (sit down before they give you the price, they deal in Euros) and see if anyone is going to have a load of rigs shipped here anytime soon. Usually, several sailmakers, sparbuilders, boatbuilders, and retailers will get together and buddy up on a shipment. We all keep in communication about potential import options. I don't know of any right now for those of us on the West coast, but that doesn't mean there's nothing going on in the east. You may want to call your local performance boat builders, riggers etc and see if they know of anything.
If you go with an offshore source, plan on missing this sailing season just to be safe. With the Department of Homeland Security checking everything, I have had shipments from AUS delayed several months.
Everyone's pricing looks accurate, between 5 and 7 G's all said and done.
Also, check out the US Acat site, you never know what might pop-up.
Hope that helps!
Posted : March 24, 2008 11:20 pm
thberget
(@thberget)
The masts are made by Southern Spars (who acquired Omohundro in 2001). They originally were made at Omohundros facility that I think was in California or nevada (they also made Farr 40 masts). Southern then sent the tooling to New Zealand and just last year sent it to South Africa. With each move, the cost has gone up.
I had written a letter to the Class Assoc. (I think it went to Mark Biggers) expressing my concern and recommending Forte as a more economical alternative. I think Mark sent it on to Performance. I definitely agree that the cost of the new boat needs to come down in order for the class to survive, but I also don't want to see the class splintered by going to a stick that does not perform. I was however very surprised at the price of a new F17 with the aluminum mast. If the 20 saw a similar reduction, it certainly couldn't hurt the class.
Perhaps all of those interested should express our opinions to Performance. I know it is not a member run class, but it can't hurt that the manufacturer knows where the class stands.
T
Posted : March 25, 2008 7:17 am
(@Anonymous 38725)
If you could buy a
better
aerodynamic shaped alum. wing type mast, would the better aerodynamics on the leading edge of the sail offset the heavier weight?
Talk amongst yourselves.... <img src=
Posted : March 25, 2008 7:58 am
(@_removed-account)
Quote
I used to use one on my TheMightyHobie18.( An E-Z mast stepper ). Yes they do make stepping easier but they take about 15 minutes or more to get on your boat properly and my rigging time is already over an hour. I have so many lines, wires and
stuff
goin on at the front of my cat with my spin, anchor lines, bridal etc… getting in there to fiddle with the mounting of the ginpole is a pain and a ½.
Another problem with that is my trailer is set up to put my boat on sterns facing my car. This allows me to have the mast at an angle for easier stepping and i would have to move the
trailer beams
around since the rear ones have cradles and not rollers.
I have found with a “helper” line tied to my halyard, If I find someone on the beach to give me a little help the line… it is much more manageable. I can handle it without to much a risk of a hernia.
I was just curious about the carbon mast. I can’t see spending 2x on the mast, compared to what I paid for the entire catamaran… but I can always dream.
Posted : March 25, 2008 8:29 am
Jake Kohl
(@jake)
Quote
T
I'm not convinced there would be a lessening in the performance of the boat - just because it's carbon doesn't make it fast and I'm certain that given enough time and development, an aluminum stick could be made as fast or faster than the carbon stick. However, there will be some performance difference and that is not good for the class - but it's better than death.
If you went to a different carbon mast supplier, I think you are still going to see some differences as the production methods, tooling, and/or materials will experience some differences. Either way, you're going to have to deal with some sort of change.
Posted : March 25, 2008 8:46 am
thberget
(@thberget)
I agree, there will definitely be some degree of change. Hall would probably be able to produce the closest thing to the existing stick, but also would probably be the most expensive (still cheaper imho). I would guess that forte could do a blank for quite a bit less, but i'm sure it would have different bend characteristics and weight (since they use an Aluminum T mast as the mandrel), but I'm guessing it would still be pretty close. I've never seen the newer F18 extrusions so have no idea on the weight of those, but you can probably get really close to the carbon stick in terms of weight (my old alum. T mast was pretty close to the current I20 carbon stick in terms of weight).
If they can get the price of a new boat down to the $13K range I think we would all welcome an alum. stick. If it would still be in the $16-17 range probably not so much. It seems when things get over $15K it gets alot harder to justify. Has anyone heard anything from the factory on this?
Posted : March 25, 2008 9:09 am
(@wildtsail308)
I've been casually quoted, by 2 dealers, a price of $23K for a new 20...
I'm decrease to 16-17 would be amazing! That's the price of a new Infusion!
I think the day of seeing these boats under $15K is long gone.
Posted : March 25, 2008 9:27 am
thberget
(@thberget)
$23K???? Ouch.
Can't sell boats at that price. $16-17 I guess is the best we can hope for.
Posted : March 25, 2008 9:41 am
(@pm)
Capt. Kirk quoted the new price at $19,600 without trailer two weeks ago at Mid Winters.
Posted : March 25, 2008 9:57 am
(@Anonymous 37989)
Quote
I think I can safely say I'd recommend this shop too. I know Mark, and in addition to being a catsailor, he's devoted to his work, and craftsmanship. His crew is a good bunch too.
Posted : March 25, 2008 9:58 am
(@wildtsail308)
hmm well my friend asked Kirk and thats what he was told and I confirmed it with Kirk at midwinters to get the response
yea all said and done, its around there
Maybe all said and done means with a trailer? In your quote, was he including taxes, shipping from the factory and etc?
Posted : March 25, 2008 10:21 am
Page 1 / 2
