freestyle 474 spinnaker
I don't think there is a cat that you couldn't pit a spin on. However, there definitely isn't one made specifically for the freestyle. Not a big problem as there isn't a spin kit made specifically for most cats. For the size of cat you would have to get a kit meant for a 14-16 foot cat. So a Hobie 16 spin kit or a Nacra 500 spin kit would work for you.
It will take a bit of work on your part, other than riviting the various bits to the mast and beam you will need to put a couple of holes through the nose of your hulls in order to rig the support lines for the spin pole. That is a pretty simple piece of glass work. The only thing is that it will likely cost you a pretty penny for the kit.
Posted : September 16, 2012 12:07 pm
Forum Information
- 5,536 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
