hobie capsize over and over and over
Daniel, thanks for the idea about the motorboat. I do have some friends with putt-putts on their rides, and one at least may be interested in giving this a try.
As for MOB drills, when I had my P-16, we used to do something similar with our throwable flotation. If the weather was good (meaning not too challenging sailing) and the sun was hot, we'd do it with live flotation, too. We got to where everyone who skippered the boat could spot a person in the water, sail to them, and spin the boat around them while the crew hauled them aboard. I'm not planning to try this on the open ocean until I can get some tiller time picking up a throwable float or a foam ball, like you and your daughter did.
As far as pushing yourself as a sailor, I'd far rather do that NOT as part of a race. But I know the temptation to just go for it is there under pressure, especially when racing. Still, that's not my cup of tea. I'm in it to have fun. Part of having fun means getting to go home at the end of the day and get back out on the water the next morning. (But I'll make sure to pass the message along to my kids in case they decide they do want to get into racing!)
Ok, MN3, the other thing you mentioned is how you would've handled seeing your crew upside down, head in the water, and tangled in the sheets. Daniel pointed out that the skipper kept the boat from turtling, which would've made the situation worse. But my gut instinct would've been to help free them, or get their head above water to buy them more time to get loose. Which one is the more prudent course of action?
I'm also glad you mentioned not uncleating the sheets before righting the boat. I thought that's what I saw, that there was tons of mainsheet that could've been let out prior to righting. But I don't know the Hobie so I wasn't sure I read it right. When I had my P-16, we capsized at least once every time we went out. At first it was because we were dumb, inexperienced and didn't know any better. Toward the end it was to give the sails a good rinse at the end of the day. But I'd say we righted that boat over a hundred times. It only took two times leaving the sheets cleated before we learned that lesson. (Why two times? Told you we were dumb!)
The P-Cat main has reef points. Reefing and furling the jib is a good one to add to the regular practice routine, along with MOB drills. Noted.
Daniel, one other thing you mentioned: having the skipper jump back in the water to use himself as a storm anchor to keep the boat in irons. Not sure I'd want to do that, especially in cold water, but do you think there would be any benefit to packing a storm anchor on a boat, tied to the bows via a bridle? Again, this wouldn't be for racing. And I'd want to make quite sure it wouldn't slip overboard accidentally. But in a situation like that it's something that could be tossed in the water to keep the boat in irons. (I'm on the fence on this one... I'd rather sail around and pick up my crew, if possible. Better still, I'd rather convince my crew not to let go of the boat!)
Thanks for the ideas, guys. I really really appreciate this.
Tom,
I feel the need to point out that the reason the boat started sailing while on its side (did you notice how the main lifted out of the water?) was precisely because the skipper moved to the back of the boat to try to help his crew. If he had stayed at the bow, the boat wouldn't have gone flying off like it did. If the crew had a trapeze cutting knife (and she should have,) she would have been fine, the skipper should have stayed at the bow. None of this applies if the skipper has reason to believe that the crew is unconscious of course. (Yes, MN3 and I are giving conflicting advice on this point.)
People have a bad habit of grabbing a boat at the shrouds or stern (especially if it is starting to move away from them,) and they think they can just hold it that way. Well, depending on the wind and sail area, even when the mainsheet is running free the boat can exert considerable force. If you want to hold a boat, whether or not you can touch the bottom, you really need to be holding the bow.
As for the sea anchor... I need a righting bag for my boat anyway so I have one onboard.
This is a scarey video. I have have lost a crew member once but was able to get back to him. It is very important to let anyone on the boat know that if you capsize you must immediately get to the boat and HOLD ON TIGHT. I feel the skipper was almost left without a boat a few times. Whenever I capsize I uncleat the main to lessen the chance of the boat capsizing again when righted and to try to prevent the boat from running away when upright. By standing on the bow or stern you can rotate the tramp out of the wind to slow the boat's speed but in these condtions I doubt that his sister would have been able to get back to the boat as it would have still probably drifted faster than she could have swam to it. Definitely makes me want to do more practice on my "man overboard drills". Agree that anyone on the boat should have a whistle and probably waterproof light or mirror in the lifejacket. I've complained about my Prindle rudders in the past but have found new respect for them after this.
i am no expert (at all) but I am pretty sure i would instinctavly check on my crew.. (alive?, hurt?, tangled?).. and would probably get into that pile of spagetti and untangled her feet. This would not have helped the boat/wind angle, and added the turtle risk... but get your crew safe, then they can help you (is what i THINK i would do)
BUT it sure is easy to say that from my desk... It's otally a matter of crisis managment where every decision can be life or death, or gear, or the race on the water.
All in all, this turned out very well. They lived, boat didn't look damaged, the finished the race i think i saw. and i bet they learned a lot 🙂
I was sailing solo on my 16, on the wire when the boat pitchpoled. I was slung forward and around the mast, the main coming down directly overhead. I was underwater, under the main, still hooked to the trap, and tangled up. Another wire was caught on the hook, blocking the release of the trap wire. I literally had to stop, regroup, and slowly, methodically detangle myself so I would swim out from under the main to get air. It was a very scary moment, I think the outcome might have been different if I had panicked. These boats are dangerously fun which is why I love them. Anything in my life that is this enjoyable involves a certain amount of risk. The issue is to mitigate as much of that risk as possible before leaving the shore.
I don't blame these folks for sailing in these conditions, I've done the same in times past. My only caveat would be to make sure my crew was equally experienced and aware of the risks.
I get the feeling there's no one right answer for how to respond to a crewmate who's tangled and head-under. I'm going to run this video by one of the EMTs I know. Unfortunately I just renewed my certification for emergency medical responder, so I won't have the opportunity to ask my instructor until my renewal comes up again. But this is an interesting scenario! I'd like to know what the better approach is.
Lots and lots of food for thought. Thanks again for all the input.
a couple weeks ago we were launching from osyc on a nice and breezy day(20-25kts) and it was just a little chilly. so we wuz doin' a little(lot) of beer drinkin' and contemplating not sailing. there was a nice youngish gent with a totaly cute chick rigging a fancy newish f18...all the bells and whistles and with complete astronaught suits. we struck up chat and and the guy sounded so competent, confident, and mind you, looked all the part. i was going to watch and see how they did before i rigged my boat, but was mainly scoping the cutie. sure enough they launch, tack twice, and then she goes into the drink about 200yrds off of the beach.
the skipper could not get back to her, he barely could control the powerful boat by himself. after a few blown tacks and nearly flipping, he headed for shore and couldn't even sail the boat in. he ended up jumping in the shallow water and with all his might walked the boat in with some help. meanwhile, the hottie was being blown in by the stiff southeast wind. at this time some kids(12-14yrs) rigged up a wave and sailed out(effortlessly) to get her but she had already reached shallow enough water and walked in. no doubt this guy was an experienced sailor(lives in atlanta, so prolly lake sailing mostly), the crew was not(but she was hot, so i understand). i guess the moral of the story is that things can go wrong real fast, they were lucky it happened right in front of the club(except for the embarassing part of the kids coming to her rescue). he lowered the sails on his boat and later took her out on a wave.
I had quiet the same experience, but on a 15ft dinghy. Strong winds, moderate waves, and a beginner as crew member. Everything OK, until unsuspecting happen, both of us in the water. I always carry an handheld GPS and after checking my crew was OK, I release all the rigs, and I mark the point on the GPS, just in case.... I take time to explain to my crew how we will redress the boat and what he should take care of and do during the maneuver. Well, bad luck, when we redress the boat, the wind blow into the main sail, which rig get stuck (I had release it before) and the boat start almost flying. I manage to step in the boat, and when I was in I realize that my crew was not there, not even close. I saw him around 75 m from the boat. I tell him to stay there, I will go back for him as soon as possible (must say that the temperature of the water is not a problem, we are in the tropics). I arrange the boat for solo sailing, and program my GPS to point to the mark were we fall. At this moment, I couldn't see my crew in the water. I recover him easily, as I had practiced the maneuver a lot of times.
Having a waterproof GPS on hand, was a good idea, mark the point, an other one. Believe me; I don't know why I did it, but in this case I went directly where my crew was, and he was no far from that point and I could see him without a search pattern.
Bill, I think the real moral of the story is if you're a 14 year old with a Wave, practice your MOB drills, learn how to rig fast, and learn how to sail back in as slow as you possibly can!
Patrick, that's a cool trick with the GPS. I can see how that should work every time. If you come back to the waypoint you set and your crew isn't there, sail directly downwind. I'm remembering that one.
jfricker wrote: That was sobering. The crew was having constant trouble unhooking, and it looked like the boat was going to turtle on top of her while she dangled from the hook. I need to think about the righting line on my Prindle, which is stuffed in the tramp pocket and not easy or fast to get to. It sure would be nice if the Prindle had a way to rig a righting line along the hull that you could easily reach, or maybe I need to think about a righting pole.
Also thinking about an externally strapped knife for quick access, a SCUBA inflatable tube for visability in high seas, bright colored hat (instead of camo!)....
Here is what you do. you can buy one like this:
Or you can make the same thing take a very small block similar to what you use for trap line return. use a short length of 1/8 in line and tie it to the pad eye you put your traveler knot through on the rear beam. You can add another tang if you want but you don't really need to.
Next you need a block big enough to handle the width of the line you choose to use for righting. If it is long enough you may be able to use the one you already have. tie or otherwise attach the block to the end of some shock cord. It should be long enough to reach from the from beam to the rear beam putting only a small amount of stretch in the line. Just enough to keep it taught. Run the other end of the shock cord through the small block you tied to the rear beam and back to your front beam. Tie it to your DS rod.
Now you have 2 choices. You can install a pad eye on each side of your front beam to tie the ends of your righting line 2 or do what I did and just tie the end of your righting line around the outside of your front beam. To do this with the tramp on push the line up through the front corner of one side of our tramp. Go around the front of your beam in a loop and reattach with a bowline knot. ( I actually went along the bottom of where the beam is attached to the hull and around the outside of the end cap keeping the line tucked under the lip and them back along the front.) Take the other end and run it through the block attached to the shockcord and back to the opposite front beam making a big V shape. Tie that end on the beam like the first one. Tie it so it is tight enough to be stretched tight while in the V shape.
Now from the bottom of the boat you can reach it and pull the shockcord will allow it to be pulled out to hang on to right the boat then when done the shock cord will automatically return it to its stored position. No need to get out and put away it's where you need it when you need it.
daniel_t wrote:
Specifically, what would you do differently?
her life vest was riding up, practically covering her face. I see this kind of problem a lot. The vest isn't comfortable so people will loosen up the straps, then when they hit the water, the vest causes more problems than it cures. Tighten up that vest! Make sure it won't ride up on you.
finally got to watch the video after using
hidemyass.com
to get around youtube's regional block
you guys already said what needs to be said
but can't resist commenting on the quote above
when i started parachuting
having all the harness real tight never mattered
as adrenaline filled body never noticed
but after getting used to it
if we had any delays, would loosen the straps until just before the jump
until forgot
and came down with the chest strap across my nose
as they say, and like that cat experience
"that'll learn ya"
HAHAHAHA! I can second that, but from another direction. I did the first several jumps in the AFF course, but then I got back into sailing and could only afford one or the other. I picked sailing. But those jumps stuck with me. One of my mentors told me NEVER to jump with loose straps at the crotch. "Why?" I asked. "Because it feels like someone kicked you in the nads if you do."
My current job involves a lot of work in high places. Any time we go up, we wear fall protection. The harness I use, a DBI Sala Exofit, looks exactly like a parachute harness without the container and risers. I'm picky about my harness, and don't really appreciate it when someone grabs mine instead of theirs, and then proceeds to change all my strap settings. People laughed at how tight I keep the leg straps until I told them the skydiving story. A lot of harnesses got a lot tighter after that!
So far it's been academic, though. I don't think we've had a single fall since I started working here ten years ago. I'm happy to keep it that way!
Dustin - I like that layout. One question, does pulling from the inside (or bottom) of the hull instead of from over the top of the hull reduce the righting moment and make it harder to right the boat? I need all the help I can righting it solo.
Wow, losing sight of the crew, serious scary stuff, way more action then what you had hoped for I bet. I bet you were exhausted after the first capsize but I'm curious about the attempted jibe actions afterwards that appear to result in two more pitch poles. At the moment what was the thoughts behind these, trying to get closer to the crew or were you trying to fix the jib to prevent further flips? Great job and thank goodness everybody was safe at the end. I'm chalking down a personal note: "Whatever happens, never ever ever EVER let go of the boat...."
jfricker: I have a Prindle 16 and I use the same righting line setup as quarath shows. I am UNABLE to right the boat by pulling the rope under the hull! I find that tossing it over the top of the hull provides a little extra angle. Anything helps! It's easy to rig underneath the trampoline and leave a knot in a circle that you can use around your wrist or just a better grip.
I have not used a righting back, basically I have not wanted to buy one. But I weigh 175 and I think that the added weight of a righting back over my shoulder combined with the rope over the top of the hull would pop the boat right up.
I keep a large "water tight" bag tucked into one of my tramp pockets, (it also works as a sail bag for my jib during storage) and I think I'll grab for that to use as a righting bag if my body weight isn't enough next time.
I'll chime in w/ some additional info on Dustin's post.
I set up my own righting system similar to the above using extra parts. I have the top of the "V" shaped line secured to the front crossbar with a Bowline. In the future I may upgrade to adding a padeye to either side of the crossbar to make it look better. For now I want to test it out before I spend any money on it.
The line is a portion of my old main sheet. I cut the old forestay pigtail off and reused the stainless ring and ran my main through the ring and secured the shock cord to the ring.
I added an old trap block to the rear crossbar with a padeye and ran my shockcord from the ring through the block to the DS rod. I secured it with just enough tension so that I can pull the righting line nearly parallel with the front crossbar. I figure this will allow me to fully hike out when trying to right the cat. I read somewhere that a bowline will hold in shockcord but I need to verify that. I played with it on the lawn and the setup is very simple and it seems to work and return to center every time.
I tool the remaining length of mainsheet and set up a traditional recovery line but added in some barrel knots for hand grips and a bowline loop at the very end so that you can put you foot in it to get back on board if you aren't the most nimble of people.
My overall cost was $4 for 2 rivets and a padeye. Everything else came out of the parts bin, You could as Dustin mentioned run a line from the traveler padeye but I opted for adding in another padeye so that the force is pulling in the same direction as the rivets versus some angle greater than 90*. I'm sure its strong enough attached to the traveler; but I had the crossbars off and for $4 I wanted to keep it neat.
Let me know if you want Pics
jfricker wrote: Dustin - I like that layout. One question, does pulling from the inside (or bottom) of the hull instead of from over the top of the hull reduce the righting moment and make it harder to right the boat? I need all the help I can righting it solo.
No, it doesn't matter, but it might be a little harder to hold on to the line since it will be more horizontal than otherwise. Also, and this is important I think, you will find it harder to stand at the bow and right the boat with that system so it will be harder to keep the boat facing into the wind.
covered in great detail here - http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=239400&page=1
I had not problem but I have the weight to do it. I think that over the top could give you a little extra.
I have seen it done like this on a Prindle as well.
In this case the line was not tied at the beam but passed trough a large pad eye riveted on the bottom of each beam then went over the top of the deck in front of the beam and trailed down the outside of the hull and attached somewhere at the back. I believe to a hole drilled through the deck lip. The one I saw had a series of knots tied along it. I though it would be to hard for me to get the line loose enough fall down from the hull in the air so opted for the other one.
covered in great detail here - http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=239400&page=1/blockquote >
I'm not sure they ever agreed! It does not matter if the righting line is over or under the top hull, it's how far out you can get when leaning back, and how much weight you carry. If you laid out on a dagger board in the same position you could lean out with a righting line, you would have equal righting moments. Thanks for clearing that up for me.
but you can lean out further with the line further away from the hull in the water... and that means... out and over the top hull (IMHO)
yes but you would be under water faster and thus loose you righting momentum
I have spent the last week trying to get this video out of my head. No can do.
Today I picked up a set of personal locator flares and a new throwable PFD. We have knives and whistles already in PFD chest pockets, and borrowed VHF radios.
It strikes me that the best tool in this situation is man overboard expertise, and using my head while still on shore. I have stood in the sand and bailed on races in the past due to severe conditions. Right now I feel great about every one of those decisions.
Thanks, MN3, for posting this. It has had significant impact.
Edited by klozhald on May 15, 2012 - 01:09 PM.
I, too, have watched this video a number of times. I have never sailed in those conditions, but I've experienced each one of those problems over several years, just not on the same excursion. I bought new PFDs with pockets, and whistles, line cutter and sailing knives for the kids.
Edited by lesgawlik on May 15, 2012 - 07:31 PM.
- 731 Online
