Keeping a Cell Phone dry on board
14 Users
ctcataman
(@ctcataman)
[#5373]
What have you used to keep your cell phone in when on board? I suspect not all waterproof cases perform as advertised.
Posted : March 4, 2016 4:13 pm
Andres Chianale
(@Andinista)
Interesting topic. I still use a megellan toughcase. It works with iphone 3 and 4 and provides additional battery and gps (only needed for iphone 3 which has a less sensitive gps). I bought it when i had an iphone 3 (or 3s whatever) basically to use an app to watch and record speed and tracks. It's nice to have that but i learned that you cannot pay attention to sailing and apps at the same time, you just kill the sailing experience. I couldn't even read the speed while sailing because my hands are busy with the main and tiller. I also learned that the cellphpne is a safety device if you have signal and battery (the app+gps+expectation to have screen on all the time will eat the battery very quickly). So i still use the toughcase but just fr the telephone. The problem today is that i need to borrow my wife's phone because mine is a 6 now. But for the price of the 6 (company phone, not even mine) i don't feel comfortable putting it on the water (i already drowned several but not that expensive). It makes more sense, when my wife finally changes her iphone 3 (i broke her iphone 4....), to keep it for the boat with a prepaid sim card. The toughcase is tough but the screen plastic can be damaged on a wreck or bad move or you can mess with the o-ring when closing it
By the way, i use the phone hanging from my neck and inside the pfd. Having the phone with you is much better than inside the tramp bag.
Posted : March 5, 2016 1:08 am
Andres Chianale
(@Andinista)
I'm still intersteed to watch the speed. Maybe i will get a gps watch sometime
Posted : March 5, 2016 1:12 am
ctcataman
(@ctcataman)
Might get a second phone just for on the water. A tracfone or some reconditioned older model I wouldn't mind seeing it sink.
Posted : March 5, 2016 2:17 am
(@timinaustin)
I use an iPhone in a Lifeproof case. It's waterproof (supposedly), but I stick it inside of a waterproof Pelican case that is attached to the boat via a carabiner. I take it along for emergency communications if I manage to do something extremely stupid.
Posted : March 5, 2016 3:59 pm
Andres Chianale
(@Andinista)
But something stupid may quite lileky separate you from the boat.
Also, if you have a phone for emergencies, you are faced to the possibility to use it for less urgent calls. If the phone is stored, you won't here the calls or won't be able or willing to answer or won't use it for a short call because it's too complicated. if you have your family on the shore it may become quite practical and give some freedom to those on the water or on the ground. On the video above it's my daughter telling me not to pick her up.
Edited by Andinista on Mar 06, 2016 - 06:35 AM.
Posted : March 6, 2016 12:33 am
Andres Chianale
(@Andinista)
So i can sail a little more until i get the time out call
Posted : March 6, 2016 12:37 am
(@dogboy)
I can tell you that every Aquapac I've owned has eventually leaked allowing my phone to get wet.
Posted : March 6, 2016 5:57 am
ctcataman
(@ctcataman)
That is good info. I am skeptical of soft cases in this application.
Maybe having 2 on board is a good plan. One in a hard case on the tramp and one in a soft case in a pocket knowing it is a yearly replacement item.
Posted : March 6, 2016 6:30 am
(@bacho)
I used to carry a Iphone with lifeproof case on the boat. The lifeproof case is the real deal, and worth every penny for an Iphone. I have no concerns about that.
But, the iphone screen is flipping hard to see in the full sun. Trying to make a call with wet fingers through the case or bag is all but impossible. I would NOT rely on a cell phone to help you out in any emergency situation.
A handheld VHF is 1000% better for this situation.
Posted : March 6, 2016 3:06 pm
(@thundercat5.2)
Lifeproof case.
Posted : March 7, 2016 4:58 am
(@tommason)
Agreed, Lifeproof is the best case I've found so far. I even use the Nuud which does not have any cover over the glass and in 2 years it hasn't failed.
I carry my phone in the pocket on my vest so it's always wet and have had no problems. I have it paired to my bluetooth speaker for tunes when we're out for a cruise and use the camera to take pictures.
Like others though sometimes the glare can cause issues and it's tough sometimes with wet fingers to get the phone to respond. I used a stylus one day and it worked great but it was a two handed effort which is difficult at times.
VHF is great and the best option for what its designed for but if you need the phone for the apps Lifeproof is my recommendation.
tm
Posted : March 7, 2016 3:40 pm
(@tamumpower)
Lifeproof, but make sure the plastic window on the back that shows the apple logo...dumb, doesnt come unstuck. I noticed mine was letting water in recently. Other than that I just keep it in the gear bag on the tramp and it's been fine.
Posted : March 8, 2016 9:09 am
I am on my second otter case - they work well... they don't float (ugg)
pocket pc's (Phones) are great and can be very useful with radar, pandora for my blue tooth radio, and more, but don't take it if you can't afford to wreck it.
Also, if relying on the radar (this is the main reason i carry one) be sure your radar loop is a current loop .years ago I misread an old radar loop on an early iphone - my cat went "dukes of hazard" (air-born) with that mistake.
Posted : March 8, 2016 11:13 am
Tyler
(@tylerh)
Keep it simple, a zip-lock bag.
Use them every distance race & never had an issue.
Posted : March 13, 2016 5:34 pm
You "use them"? how?
do you mean you actual use it for calls, pics, video, gps, bluetooth or other?
or do you mean you have it stowed away somewhere in ziplocks and you haven't had a leak?
TylerH wrote: Keep it simple, a zip-lock bag.
Posted : March 14, 2016 2:06 pm
Tyler
(@tylerh)
MN3 wrote: You "use them"? how?
[quote=TylerH]Keep it simple, a zip-lock bag.
Used it for calls, and plenty of pics during RTI.
Keep it in my life jacket pocket.
No leaks yet!
Posted : March 14, 2016 7:03 pm
nice!
I lost an iphone about 13 months ago and it cost me over $400 to replace so I am not so willing to risk my phone with that "light" of waterproofing
I keep mine in a drycase, in a ziplock, in a drybox
Hope yours continues works without incident !
Posted : March 15, 2016 12:59 pm
(@klozhald)
bacho wrote: But, the iphone screen is flipping hard to see in the full sun. Trying to make a call with wet fingers through the case or bag is all but impossible. I would NOT rely on a cell phone to help you out in any emergency situation.
Agreed.
I have a great app, MotionX-GPS, on my iPhone that I have tried to use racing multiple times.
The failure is that it simply cannot be read on the water, on the two models of iPhone I have tried.
There is a high contrast setting, and the Lifeproof cover is absolutely clear, but the sun is just too bright and the screen not bright enough.
The situation is very frustrating. The app is feature loaded, and I have put it /in a ziplock/ inside a peanut butter container/ inside one of the hulls/ to record my race, and it did so very well.
Posted : March 16, 2016 11:41 am
(@antonlargiader)
There are ziplocks and there are ziplocks. I recently used a Sea to Summit case for my iPhone 5 and we turtled (first time ever) and it was a bit disconcerting to see our gear completely underwater with bubbles coming up but fortunately they were only from the mast. D'oh! Have to seal it! Anyway, it is one robust ziplock and I will be getting one. Supposedly has a touch-through membrane.
http://www.seatosummit.com/waterproof-gear/?sub_wpg=2
Posted : March 30, 2016 1:17 am
André
(@catmodding)
Modern smartphones are way to expensive to take out sailing,
they are hard to monitor in the sun. So, why don't you go
this way?
After toasting 2 samsung "waterproof" cellphones and one smartphone
in a aquapack, I ran into this...
A Ruggear RG100. Its cheap, under a €100,00
I keep it in my pfd in a kitchen zippered plastic bag made for
freezing food. But I can stil use the dials.
I change the plastic bag every month or so.
It has a dedicated prepaid simcard.
Battery-life is 2/3 weeks on standby, and it is loud, very loud.
Works like charm.
Of course its for emergency situations only.
For "toying" I have these other gadgets;
In the tramp-pocket there's a Standard Horizon SX280
For tracking I use a Garmin Forerunner 101 wristwatch, strapped to
the boom. Turn it on and never look at it.
Digital speed display is the old Garmin foretrex 201, but
I take it less often because I just wanna sail and not be bothered.
Regards, A
Edited by catmodding on Mar 31, 2016 - 04:55 AM.
Posted : March 30, 2016 3:39 pm
(@spoulton)
I really like the Snow Lizard case. It's a hard case that adds extra battery life and even has a solar panel to charge the phone if you leave it out in the sun. Have been in the water with it multiple time and no problem with my I-phone. Can dial and can usually see information on screen unless in very bright sunlight. Listen to music on cat via Spotify with waterproof Excogear speaker that has Bluetooth. Run apps such as iRegatta Pro and raceQs.
Posted : March 30, 2016 4:18 pm
