Low Budget Cool Weather Gear
in-shore pants, lots of layers, full bootties, 3 or 4 sets of gloves (so when they get wet you can swap out with dry ones), a wool cap, spray gear, dry bag full of extra clothes incase you dump).
Make sure you realize how heavy your gear is when wet (esp fleece), and that wind gear is worthless when wet
MN3 suggestion = Lexus - you will be very comfortable all day.
matt922 suggestion = Toyota pickup - It will get the job done.
Personally, I get cold really easily, so I went the Lexus route to the tune of almost $300 That said, a $100 wetsuit would be money very well spent.
over in ocean springs I wear a 3/2 farmer john... w/5mm booties
under that i wear the booty foot liner things, and I cut some polypro long john pants to knee length.. and a polypro shirt under a spray top.
the poly pro is great base layer stuff... it's cheap, get some at a mil surplus store.
the polypro i wear under shorts in fall... and the polypro top i wear under my lifejacket in fall... the top however I cut the sleeves out off... kinda redneck, but that's how we roll. 🙂
you could get a sunny day in the high 60s. go to Juanas. they're cool and you can leave the boat on the beach overnight...
HULLFLYER wrote: Just make sure that you have the proper gear on for the worst possible situation. If the water is 78 that is still 20 degrees less then your core temp.
78 is like bathwater compared to most of the lakes I sail in even in the middle of the summer. We consider 60 to be warm I've sailed in 45-48 in shorts.
That said these are not coastal conditions and not alone or isolated without reasonable help around. I also have a lot of natural insulation built in. 😉
I never sail without a wetsuit, watertemps around here don't top 60! So with only a bit of spray we get cold fast around here (denmark!) we can only sail in wetsuits here from April to October.
Normally I wear a 2 mm longjohn and wetsuit booties no top, only lifejacket and harness. love the freedom of movement. keep moving to keep warm and don't go out of protected waters.
In the spring and fall I sail in a full suit 3/2 or 5/3 for the colder days. I sail until the watertemps hit 45, the customers don't get lower then 50.
- 2,227 Online
