Mast floats?
Page 2 / 2
Prev
General Sailor Talk
34
Posts
12
Users
0
Reactions
10.5 K
Views
f i can paint a car i think i can paint a boat http://www.face...ef=fbx_album
but the sanding is giving me trouble i power buffed it, but too much work for too little return. and currently im just using 130 grit. whats the best way i can go about wet sanding it?
Uh no that is not the same. Unless your car is a Corvette. Of course you made have hobie 18 that is made of steel.
Posted : October 16, 2010 6:08 am
Your right, but I would not suggest using anything over 1000 grit uless you are planning on gel coating again.. Find a small flexible sanding block, Dip in water and sand. Also be sure to use a buffer not a polisher. There is a big difference. You would be amazed at how good it would look afterwards. Also no cheap rubbing compound.
Posted : October 17, 2010 5:36 am
Page 2 / 2
Prev
Forum Information
- 5,778 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
