My second Hobie 16, ready to go
We finished up a bunch of details today.
We had a few discoveries:
1) The main is a lot easier to raise. I think the old main halyard sheave is probably shot.
2) The jib is a lot easier to raise. We pulled out the old jib halyard sheave and it was badly worn - I don't think it was spinning at all. The new one was a little worn, had a bigger OD, and I greased it up.
3) Since I got a closer look at the rest of the hull, other people have done bodywork on it. No worries, as long as it doesn't break or leak.
4) We had been using the step hinge installed backwards. Now the mast always drops in.
First sail tomorrow.
you found the hole! (no wind)
besides the hole, it looked like perfect wind to test newly repaired and rigged boat
if you are desperate to get a hull up do the "wild thing" (sit on the low side). it is actually a racing technique that has been around forever but it can get pretty exciting in an unexpected puff.
but in light to mid air, (if you want to play or are actually racing) get your crew to move in more and more till you power up (or out/ down) as needed.
ad I not had a foot hooked under the strap I would have been in the water.
amazing how critical a $10 piece of webbing (est retail) is vital for safe (and dry) sailing
Edited by MN3 on Aug 09, 2021 - 05:10 PM.
We will try that. Would give us more practice time flying a hull.
MN3 wrote: amazing how critical a $10 piece of webbing (est retail) is vital for safe (and dry) sailing
Here is the webbing I bought and sewed on! The old webbing was rotten.
https://www.amazon.com/gp/product/B01KTVB9E0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Good example of the "wild thing"
as per your "light air" ... it looked heavenly to me
current sailing conditions here on the gulf
humid and 92" water (gross)
2 knot easterly shifting for an hour until 1pm the seabreas sets in fully (painful to roast on a boat not moving, jumping in gross salt water doesn't help much)
moderate amount of dead fish in the water, tons on the islands, med to high concentrations of (over 1 mill parts per liter) red tide and afternoon lightning
I haven't sailed in 2 months - almost last weekend but high levels of red tide and those exact wind conditions.
Hoping again in 2 weeks, but wont be sailing a lot until fall weather and the algae blooms die off
Edited by MN3 on Aug 10, 2021 - 08:23 AM.
Come up to my place, the border is now open to vaccinated American citizens. Waters a comfortable 27C (80F), water visibility 20’, & the winds today 30kph,(18moh), with stronger gust if a thunderstorm occurs.
Of course from November til next May, I’d sooner be in your water!
I did a lot of sailing last fall. Tends to get windy and with a wetsuit it is good to about 50 degrees F. I think I had to quit late November due to temperatures.
The good thing about the plains states is we invented wind here. Not much to stop it.
I like the wild thing video. Besides learning to fly the hull, I think we need to get to deep water and practice capsizing and righting the boat. Then we would have the courage to hang it out a little more and maybe do the wild thing.
Edited by waiex191 on Aug 10, 2021 - 09:22 AM.
haha - i spent a few months in Waukegan ( all of Oct and Nov)... windy and brrrrrrrrrrr
Yea, you're gonna flip if you do this often
Can you swing by and grab me via plane? i will bring a spinnaker we can rig on one of your cats 🙂
Unfortunately, no. Your Govt will not yet let Canadians in for non essential travel. Bit of a bummer. I used to make numerous trips across the Line each year.
Half my neighbours here own property in Florida, & haven’t been down for 18 months.
We had primo conditions today...overcast, so no sunburn, 30C, humid, & steady wind of 35kph. My wife was soaked, even being on the wings.
A neighbour came out, with his 1973 H16. He bought a brand new set of sails for $700. Apparently a sailing school in the US went under before delivery, & the vendor was trying to cut his losses. Nice colours, & fast. We did a bunch of 5 miles legs. He had the 16 airborne off some of the big waves/swells.
Edited by Edchris177 on Aug 10, 2021 - 11:21 PM.
For the past few years, I've achieved a pretty high level of confidence that I've screwed up everything one possibly can on a H16. I've continued to screw things up, but they have been repeat screw ups, not new ones. Until the week before last on vacation in Dauphin Island AL, that is.
Despite the big arrow and large font word "UP" stamped on its side, I installed my hinge upside down. Funny thing is mine worked pretty well that way!
Glad to hear of the fun you're having with your boats, man!
Edited by rattlenhum on Aug 15, 2021 - 07:05 AM.
Don't get me started. We routinely go down to Montana to sail and range outward from there, and this is the second summer that we've been shut out - even though a week ago the Canadian border was opened to Americans. The continued closure makes no sense at all. Even Bill Maher raised it on his show on Friday.
One of the good things about putting hatches on the boat is it lets you add a fuse for a hull pressure test. I taped over the hole, figuring the tape should fail before the hull. If the hull failed first, then it's probably toast anyway. I also used my little shop vac, instead of the big one, and didn't plug the hose in all the way. You really don't need much pressure.
And hey - I found a leak!
When I took off all the silicone, and sanded out the cracked gelcoat, the glass looks like it had a void from the beginning (1978).
I put about 5 plies of 2oz cloth on, 3 on a straight cut and 2 on a 45 degree bias. I made each one a little shorter.
I actually took off all the silicone, sanded out the cracks in the gelcoat, and flooded them all with some resin.
Next I'll do another leak check, then wet sand & paint.
Also, no leaks from my repair that I ended up documenting on the ventilation hatch thread. I think that repair is pretty solid.
Edited by waiex191 on Sep 11, 2021 - 06:40 PM.
I did another leak check and found a couple of small ones under the lip. This is just like looking for oil leaks on engines - get the big ones first, then the medium ones, then the small ones. I've ground out the gelcoat in the two leaky areas and have laminated a few plies under the lip. This hull should be good.
The H16 is back together. Here it is with my invisible trampoline installed:
Weight increase for all the repairs, adding the hatches, and painting was a little less than 2 lbs. I'm pretty happy with that.
One of the issues I had was the holes in the casting didn't line up with the hole in the pylon on the inside. I ended up making the hole bigger, which was a bummer.
Now that it is done again, wind is 3 kts forecast to get to 8 later in the day, after my kid has to go back to school.
Edited by waiex191 on Sep 19, 2021 - 11:52 AM.
- 840 Online
