NACRA 5.2
I recently bought a NACRA 5.2. This is my first catamaran. I have a question on the mast there is no spot to put a pin to hold it on the ball. Should there be?
Also I am having trouble with rigging the mast does anyone have a link for instructions. I am a little confused on the trapeze wires.
Please help.
If you have one trap wire the bungee connecting them runs through the front beam. You probably have a non captive base. I have one and it is not that big an issue. There are plenty of pictures of 5. 2 in the photo album. Between wolfman and erice they will have a picture of what you want to know.
there is a period nacra manual somewhere in the tech files
the 5.2 was made from 1975 through to about 1985
the early models only had 1 set of trap wires, swagged at the top to the sidestays and only 1 mast hound. the 1 set was for the crew and as golfie says the bungee sucking the 2 wires together at hull level went through the front beam
about 1980? trapping the helm also became popular so a 2nd set of rear trap wires was added. this bungee went through a couple of too small 5mm? eyelets? on the outer hull just aft? of the dagger, then across the hull and down a grommet in the tramp. under the tramp and up the other side through a grommet etc.
with 3 stays and 4 trap wires the mast hound was over-crowded so about 1983? nacra put a 2nd mast hound up there.
nacra assembly manual
bernd
I agree with Golfdad here. As long as the old ball and castings are in good shape it isn't absolutely necessary. One caveat though, when stepping the mast you will want a someone holding the mast step on the ball so it won't pop off. This person should be positioned to the side of the mast so they don't get skewered if the mast pops off (common sense I know). Some people have also gotten away with tying the mast down to the front beam to hold it in place. Once the old one breaks or the ball wears out you will need to upgrade.
Dave.
I just got 2 new mast balls in the old size.. .. Will dig up the link when I have a sec.. Seems to me that the tention of some one helping to step the mast with pressure on the forestay holds the cup on the ball quite well. I am doing a steping assist system which will hold pressure on that ball during the process after the mast is 20 degrees up..
I think the most dangerous/difficult part of rigging your before sailing is raising the mast. I think updating to the captive mast system is worth every penny... a lot cheaper than hurting your boat, yourself, or your friend helping you raise the mast. It is not difficult to do either. You just need a drill, a hand rivet gun and some silicone.
My wife would strongly disagree. The most difficult part is putting the ring through the pin on the forestay. I personally think it is coaching your wife to put the pin in while you hold the mast. 😆
Edited by golfdad75 on Oct 06, 2011 - 10:07 AM.
- 5,150 Online
