P 18-2 footage
André
(@catmodding)
[#4287]
Hi,
Its winter and I made a small video sailing my P 18-2.
Bloopers included.
You can turn the music of..... :-))
André
Posted : February 7, 2014 9:55 am
Nice! Where and when was that taken? Cold much?
Posted : February 7, 2014 10:07 am
André
(@catmodding)
Its just a bunch of clips sitting on my mac waiting to be edited for the past 1,5 year.
Most of it is shot at the Yselmeer, the Netherlands. You know, biggest catclub......
The lady falling in the main was shot at a trail for the round Texel race 2012 .
Yes, I love cold-wheather sailing. Spring and fall make for the best wind conditions overhere.
André
Edited by catmodding on Feb 07, 2014 - 11:37 PM.
Posted : February 7, 2014 10:30 am
(@klozhald)
Thank you André!
Fun video.
Had any time to work on that Tornado?
Posted : February 7, 2014 11:53 am
(@emmettv)
Nice video , Andre .. Garmin speedometer is a great idea. Noticed your Spinnaker setup , can you tell me what parts used .
I want to set one up on a P19 .
txs
Emmett
Montreal,Canada
P19 mx
Posted : February 7, 2014 11:29 pm
André
(@catmodding)
emmettv wrote: Noticed your Spinnaker setup , can you tell me what parts used .
txs
Emmett
Montreal,Canada
P19 mx
This is what I used;
a 2,7 mtr aluminium tube, 50mm diameter
a stainless steel strip 150mm x 30mm 2mm thick (bent in U-shape,
so 50mm wil fit.)
2 thin SS wires with eyes splitted at the ends
2 SS small spanners
3 SS bolt eyes
2 plastic end-caps for the tube
a second-hand polyester snufferhoop 50mm (To expensive new!)
a new snuffersock, lenght for midpole setup.
1 ronstan ballbearing single block for halyard
2 ronstan ballbearing single block & 2 1 ronstan ballbearing double block
for sheet.
2 Spinlock PXR cam cleat jammers ( one swivelling)
Second hand F18 spi.
Shackles, lines, rivets, bolts and small stuff.
Riveted the strip at the frontbeam just under the mast, drilled holes in it
and in the tube. Then bolted the tube to it.
Drilled 5mm holes in the upper-front sections of the hulls and epoxied
small aluminium tubes in it.
Didn't want to drill holes in the hulls, so attached the sheet-blocks to the
back-stay-chainplates. F18 class-rules states the height of the halyard-block
should measure 8150mm from the mastbase.
So, the head and clew positions are fixed, now find the perfect tack-position.
This is a matter of trial and error, pole up you can sail deeper, pole down
you can reach better.
Moving the tack foreward or aft determines the sheet angle.
I didn't install the snufferhoop and sock and used kevlar lines to keep
the boom and tack-block in place whilst finding the perfect tack-position.
SS bridles where made after this. And I shortened the pole 60 cm.
Hope this will get you started.
Since you sail a P19, you can also opt for a tornado spi, more fun !
I used an F18 spi because I solo quiet often.
Grtz, André
Posted : February 8, 2014 2:57 am
(@marekli)
nice footage Andre, I will be studying it more to hopefully pick up some things that will help me better sail my P19. May also be interested in more details about the spin setup down the road.....
I will be in Cologne to see family this Summer and my wife loves visiting beaches in the Netherlands...maybe I will see you sailing some time then... although it may just be to warm for you in July...jk...:)
Posted : February 8, 2014 4:23 am
