PFD & Wetsuit storage
local sail shop owner said this to me recently (when i told him how my 5 year old ronstan spraytop "exploded" in my dryer) - treat this gear like a garment and it will last a long time, store it in your trunk and it will die quickly
I keep my pfd attached to my tramp for my 5 mile drive home on sunday and it gets a good hosing down with the boat, then air dry, then hung up in the garage until friday
rise and repeat
I have 5 different wetsuits, from 2mm shorties, to Farmer john, & an expensive 5mm semi-dry with hood, (toasty warm in 5C water) by Cressi.
We use them every day early & late in the season here in Canada.
The good ones are to expensive to murder.
As said, the inside can stay wet. They need to fit snug to be effective, & so they generally get turned inside out when peeling them off. If it's a 2pc, hang each piece separate, on a "thick" plastic hangar. I always give them a swoosh in the lake before hanging, you can sweat quite a bit in them. If I'm going to be hanging around for a bit, I hang them outside on the dock, they dry quite quickly there. If not hang them inside, but not touching each other. I never hang them in a closet, Satans Spawn breeds there with wet things. I have an 8' dowel under the shelf we store unused sails on. All wetsuits get hung there awaiting use.
If you have to use a closet, leave the door open. Another option is a small block attached to the ceiling, you only need to be 6" off the wall. Hoist & tie off.
Prevention is worth a ton of cure. If the neoprene goes skunky, it's really hard to get it all out.
Edited by Edchris177 on Jul 08, 2017 - 06:16 PM.
- 4,992 Online
