Sailing Eyewear?
Recommendations on goggles to wear while sailing?
Currently wearing glasses, but will switch to contacts in a few months and wondering what others use to keep the seawater outta eyes.
Have googled it, but the results are almost all sunglasses, and I know there are more goggles out there.
Does anyone use ski goggles?
The good polarized goggles I have found are nearly the price of the Gath retractable helmet at Murrays, which I would prefer for the ocean, but $190 is steep!.
They aren't goggles but they support several regattas I go to and my wife wears contacts and has switched to them. Check out Sea Specs.
http://www.seaspecs.com/html/specifications.html
I thought about trying them, especially when 3 up on the 5.7. In those cases 2 on the wire & I end up sitting on the hull, foot braced against the traveller casting, eating all the waves.
I have 1/2 dozen different ski googles, I think they all have the same weakness for sailing. The liner that goes against your face is a type of foam that would hold water, plus all the vents are foam covered. All good quality ski googles are double lens, to help control fogging. I have not actually tried a pair, but I think they would accumulate water between the lenses. It would drain, but not instantly. Built for cold weather use, the venting is not huge, they fog badly when you sweat in warmer weather, & or be the cause of sweat running in your eyes.
The cheaper single lens ones "might" work.
You bring up a good point though, I'll bring a pair up for a test drive & report what I find under actual use.
I do like Wolfman, buy 1/2 dozen pairs of knockoff Bolle or Raybans in Shanghai, then put those $1 floater straps on them. I leave several pairs hanging on the gear hooks at the back door so guests don't risk their expensive lenses.
Edited by Edchris177 on Aug 21, 2013 - 09:47 PM.
An alternative to ski goggles might be motocross goggles. Not sure how the venting compares to ski goggles, but might be better warm weather venting.
When I sailed our SC20 in the ocean I wished for glasses with wiper blades since the salt would build up so bad. It felt like a saltwater firehose shower.
i used ski goggles in heavy air
the salt water destroyed them quickly
200 for prescription sunglasses is not bad
i got a pair of polarized ray bans for about 240
$2 glasses? - do you think they actually have uva/uvb protection? here in florida, it's not worth the risk
Edited by MN3 on Aug 22, 2013 - 07:19 AM.
nacra55 wrote: They aren't goggles but they support several regattas I go to and my wife wears contacts and has switched to them. Check out Sea Specs.
These do look good! And at $55, they do not break the bank.
I am hoping to find something that does not allow the salt water to drip down my forehead into my eyes.
These have vents on top- do they drip in her eyes?
Check these out....they are pricy, but they work well.. And the come in prescription too! Do you have a prescription plan?
http://www.murrays.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=B-SP&Store_Code=MS
Intensity Sails has a sale on "Waveshields Watersports Sunglasses" that look similar to the SeaSpecs. You can pick up a pair for $16 (available in Black on Black only).....
http://www.intensitysails.com/wawasu.html
I found a website that offers prescription sun glasses. If you just use single vision(i.e. not bi focal or any of that) lenses, they are only 26 dollars. I'm looking into picking some up. I just realized a few weekends ago that I am in denial about not needing glasses while sailing...the hard way. All I need to do is go to my eye doctor and see if they'll come off my prescription info, so I can send it to the website and I'm good to go.
It depends on what your using them for: If your sailing a cat in the ocean when it's honkin and the spray is like someone has a high pressure hose at your face, then the only think that I thought worked were the Barz Googles that Murrays Sells, prescription too at about $200 that JohnES has a link for above. This is sealed like a large swim goggle. The motocross and ski, I have both tried and they get wet on the inside and are good only for a short bit. I keep the Barz in my water proof bag on the boat and only get them out when I need them, and wear just regular sunglasses when it's not smacking me in the face. It's really not so much the smacking as it is the salt getting to your eyes after a while. It gets to be no fun, stings after a while and you flat out can't see.
Needed protection for my eyes. SeaSpecs are great and the strap is comfortable. RainX says not to use on polarized lens. I rinse mine with water. 😎 The price is right and you get one free when you buy 2. Lots of frame colors and lens options. Check them out - www.seaspecs.com
- 4,762 Online
