Trailex Aluminium Trailer Tubing
I have a trailex aluminium trailer which holds my Inter 20. the trailer is a few years old, its a very "standard" trailer nothing special. The tubing is rectangle with a grove down the center which I can slide in a bold, add on an attachment, and tighten the bolt and the attachment will stay in place.
im looking to raise my cradles up by the thickness of about 3 inches, and the easiest way to do this would be to add a 6 inch long piece of trailer tubing under my cradle. my trailer already has one of these 6 inch sections, so im just gona stack another.
im doing searches on google for "Trailer tubing" and im not getting anywhere. i should be able to buy this tubing by the linear foot somewhere right? if i could get a 2 feet section, i could hack saw it down to the four 6 inch pieces i need.
just thought i'd ask this forum, to see if anyone know where to get this tubing from.
Thanks.
Call 800-282-5042 and order a piece of the extrusion or order this:
http://www.trailex.com/options2.cfm?id=115
I would just call them . . .
nher207 wrote: im doing searches on google for "Trailer tubing" and im not getting anywhere. Thanks.
Use keyword aluminum extrusion tubing". There are tons of different vendors to choose from. The easiest one to look up is McMaster Carr:
http://www.mcmaster.com/#t-slotted-framing/=l86iq3
My aluminum Trailex has the crossbars(that the cradles are attached to) fixed to the underside of the longitudinal stringers. Could you not just undo the fittings & move it to the TOP of the stringers?
That would raise the cradles by the thickness of the original beams.
- 6,390 Online
