What size (width) cat trax for Prindle 16?
You need the 8 foot axle without cradles.
http://www.floridasailcraft.com/CatProducts.htm
the tiger trax or cat trax. The black balloon tires work much better over uneven surfaces.
Posted : March 11, 2014 3:50 am
use a ss cable 8' in length with a small loop at each end. i run the cable under the front crossbar, thru the cutouts in the boards, and use a combination lock that is inserted thru a hole in the end of the axle and thru the 2 loops. i store the boat on a beach, you might need more length for the trailer. just measure.
Posted : March 11, 2014 8:49 am
Forum Information
- 2,197 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
