H18 input
Based on my first thread regarding boats I am considering, this H18 came for sale but is a 6 hr drive to look at it. No wing seats which if I buy a H18 I would want them, trailer frame looks rusted but allegedly has new tires and wheel bearings.
Is the hull color a faded bright yellow, or faded mustard yellow? And the white / cream colored tramp being "original", what is the likelihood of falling thru it first time my 240 lbs lands on it?
Seller claims boat is "all original" and in great shape, which to be honest sounds like an impossibility and load of B.$. Won't give me the hull number so I can determine what year it was built, and all in all evades my detailed questions................
SO, from this picture, do you see anything wrong with this boat, like maybe a bent / broken mast on the forward cradle? What would you pay for it as is? I am thinking total cost to acquire including gas and hotel shouldn't run more than $600 tops based on what vague info I have on it.
Any thoughts on this, or should I pass and wait for something better to come along?
click the image to see it bigger
I've asked about checking for soft spots, delaminations, cracks in hulls, mast and beams, rudder and board conditions, rigging, sail condition and number, everything there is to ask about and all I get is................ boat is original and in great shape.
The mast looking busted in that pic has me most concerned more than anything right now. Am I seeing things or is there actually a sharp crease in the mast on forward cradle which the diamond wires look to be pulling against?
This boat is in the North San Diego area, if anyone wants to verify its condition I will send the location and owner contact info.
Yeah the wings might be a deal breaker on this unless he has them. I have asked about them and all I get is " all gear included and all original"........................ which tells me this guy probably doesn't know squat about this boat.
pbegle wrote: I didn't hear you ask the owner to press down on decks with both hands (20-30 lbs) to check for hull softness. This is first thing I insist an owner to do. Pete
I would not invest in 6h of driving if the seller is uncooperative. Ask for more detailed pictures, including the sail. The boat looks older, perhaps from early 80's.
Hi there.
I am located in mid Orange County, so could get to N San Diego County without too much work.
either PM me here or call my cell at five six two, three two eight, four one one two
I know my signature states Delaware bay, but we are now bi-coastal, and I would be happy to check the boat out as long as the owner is a bit flexible on timing to show it.
I also will be shooting over to Phoenix for Thanksgiving with a tow vehicle if that can be of help
Best
Harry Ward
renegade wrote: trailer frame looks rusted but allegedly has new tires and wheel bearings.
Probably a low-end plain steel painted trailer instead of galvanized, but could be ok.
If the hulls are "original" and not repaired, then the yellow can really pop with some elbow grease or chemicals (Poli Glow).
Yes, you are very likely to fall through that tramp the first time you "bounce" on it, replace it.
http://stores.tampacatamarans.com/-strse-5/Hobie-18-Aftermarket-Trampoline/Detail.bok
renegade wrote: Won't give me the hull number so I can determine what year it was built, and all in all evades my detailed questions................
Huge black flag, six hours is a long and expensive drive on speculation. However if the price is cheap and the boat has all it's parts, daggerboards, rudder system, sails etc. then maybe take a chance.
renegade wrote: SO, from this picture, do you see anything wrong with this boat, like maybe a bent / broken mast on the forward cradle? What would you pay for it as is? I am thinking total cost to acquire including gas and hotel shouldn't run more than $600 tops based on what vague info I have on it.
The picture isn't good, but I don't think the picture shows a bent mast, I think what you are seeing is the white main halyard angling across the mast. At $600 I'd grab it no matter what year it is as long as the hulls don't have serious damage.
If he doesn't have complete paperwork, title, current registration he probably can't sell it in California so you've got that advantage.
Based on the hull color and graphics, this boat is an early '80's vintage, roughly 1982 to 1984. So you're looking at a 30 year old boat. The resolution on the picture is really poor, so it's hard to get a good grasp on the condition other than it is clearly quite faded so it's sat out in the sun for a while. The tramp likely started out yellow and has faded to a "cream" color as is quite common. For a 30 year old, sun fried tramp, I'd say it's very likely that you will go through it. The hulls don't appear to have the upgraded crossbar anchor plates. Normally, I would ask the owner to take pics under the hull flange where the crossbars bolt up to see if there are any cracks as this is a common failure location. If it's cracked, probably better to just walk away. Either way, you should definitely add these. The pictures don't show the rudder system. Hopefully that means that they were stored out of the sun and doesn't mean that they were lost. Hard to tell if the mast is bent, I agree with the prior response that likely what you are seeing is the main halyard being routed over the front mast stand. But, I would ask the owner outright to give you details regarding condition, damage, and completeness of the boat. If they can't give you reasonably satisfying answers, then don't make the trip. Not worth it IMO.
Keep in mind that just from the description and issues visible in the pic, you would be looking at replacing the tramp ($450), upgraded crossbar anchor plates ($80), standing rigging ($250, if it's 30 years old, definitely replace), so about $800 just to get the thing safely on the water plus your $600 to go pick it up and you're looking at almost $1500 in costs before you even buy the boat. Not saying don't do it, but I would want to be darn certain what I'm in for before making the trip.
I'd ask for more pictures ( at least half a dozen ) but the mast looks straight, the trailer has a rear mast support and the hulls look good - no waved sides, obvious repairs, no gouges. The tires are inflated good and theres padding on the straps that hold the boat to the trailer. Signs that the owner cared for it some. I've seen faded hulls like that buffed out to a killer shine. If' its got a comp tip mast, solid hulls, decent sails and everything is included to sail, i'd say go for it! A good boat is worth the drive.
Here is my email conversation with this seller so far............................. don't know if I will bother calling him or not. It is clear I am not going to get any answers to my questions or better pics. I might take up the offer for someone to go look at it for me though.
Oldest to newest:
Me:
> Hi there, are you still trying to sell a Hobie 18? Can you tell me what year boat it is? Are there any soft spots and delaminated areas on the hulls? Does it have Main and Jib sails and are they original cut or more modern cut? What color are the sails? Has the rigging ever been replaced? How about the condition of the Trampoline? Does this Hobie 18 have the Wing seats? Are the rudders in good shape or do they have nicks and gouges on the edges?
> Is the trailer highway worthy or does it need wheel bearings and work on lights etc?
> I am looking for another boat and this might be something I am willing to drive 300 miles to look at / buy.
> Thanks,
> Marc
Him:
Hi ever thing is great shape trailer has new bearings tires my # 760-294-xxxx thaxs Eddie
Me:
I didn't see the dagger boards, rudders and tiller in the pics, you do have them right?
When was last time you sailed the boat and has it been mostly ocean or lakes?
Do you have any other pictures you can send, Long drive for me to come look at it. Would like to know that if i make the drive I will actually want to take the boat with me.
Also, Will be taking it to Arizona, so how does that Cali ownership transfer work? Do you have a title for the boat or something like that?
I might call you tomorrow, when is best time to call? I work 12 hour shifts and have wed- sat off this week.
Marc
Him:
Hi Marc all gear sails great shape trailer ready new tires/bearings paper work good call any time thaxs Eddie
Me:
Eddie,
Can you take some more pictures of the Hobie 18 and sails please? From the pic on Craigslist, it looks like the mast is bent or creased at the trailer forward mast support. It could be an optical illusion but I need to make sure before I spend money on gas to drive out there to look at the boat.
Also, How long have you owned it, and when was the last time it was sailed?
I will try to find time to call you this weekend about it but would like to see more pictures before I call you.
Marc
Him:
She's in all great shape sails redders center brds hull
fxloop wrote: I'd ask for more pictures ( at least half a dozen ) but the mast looks straight, the trailer has a rear mast support and the hulls look good - no waved sides, obvious repairs, no gouges. The tires are inflated good and theres padding on the straps that hold the boat to the trailer. Signs that the owner cared for it some. I've seen faded hulls like that buffed out to a killer shine. If' its got a comp tip mast, solid hulls, decent sails and everything is included to sail, i'd say go for it! A good boat is worth the drive.
- 3,363 Online
