Is it better to sto...
Is it better to store a cat with mast down ?
willy
(@kingwilly)
[#1800]
Currently, I store my cat out in the open with mast up. But I'm thinking perhaps it would be better to drop the mast between weekends.
I'm in Indonesia, so sun and rain are the only elements that get to it.
Posted : January 31, 2011 8:15 pm
(@gheniki)
I would keep the mast up. The wear and tear and potential injury risk of raising and lowering the mast every weekend outweigh the minimal wear and tear of keeping the mast up. Just my opinion, of course. Additionally the convenience and the time saved of keeping it up makes it even less of an argument.
Posted : January 31, 2011 11:21 pm
Scott Finley
(@smfinley)
You should be fine storing it mast up. You should look to replace your shrouds more often if you leave it up all the time. I store mine mast up all summer. If you aren't going to use it for a month or two I would take the mast down. But if you use it most weekends no need to take it down.
Posted : February 1, 2011 8:12 am
I leave mine up all summer. It might be prudent to take it down if you are in the path of a serious typhoon.
In some ways metal is not as good as wood, it suffers from fatigue after being subjected to numerous load cycles. Cats are usually left on dry land, so don't experience the constant rocking that a moored boat would. I do slack off the shrouds & diamond wires a bit, but is just way easier to leave the stick up.
Posted : February 1, 2011 1:54 pm
 trvo
(@trvo)
Personally I store mine with the mast up except in the winter where it doesn't get used much (and the winds are higher)... I also remove the mast if a storm is due. Some insurance companies here in the UK don't cover your boat if you leave the mast up in the winter...
Trev
Posted : February 1, 2011 11:40 pm
