Snuffer wanted to purchase
The Miracle 20 is a pretty clean and fast boat upwind. Competitive with the newest tech. Adding a furling kite reduces upwind performance. A SNU generally minimizes the upwind hit. A F18 snuffer probably won't work for this kite though; the hoop will but the bag is far too small as the F18 kite is only 225 ft^2. To that end you would want to look for a Nacra Inter 20 setup I think, inclusive of the kite (25 m2 or 270 ft2); the 450 ft^2 kite that Hobie originally designed for the boat is far too large and was originally intended for dead downwind running which was quickly determined to be inefficient as VMG running is much faster on a spinnaker catamaran, and a smaller kite is more efficient (a lot less drag). Also this kite probably doesn't have take down patches installed, getting those right is important.
To that end you can order a longer bag from SNU or go for a complete Nacra setup from one of there dealers.
Good luck.
you can always add a foot or so to the end of a f18 spin sock too
this is a pretty easy job for anyone who can use a sewing machine or self stitch (neither can i do well)
I got one for my F18 from Barefoot Studio. I'm sure they could make one to suit.
http://gobarefootstudio.com/store.html
ropewalker wrote: I got one for my F18 from Barefoot Studio. I'm sure they could make one to suit.
http://gobarefootstudio.com/store.html/blockquote >
when did you purchase?
OP says "SNU is no longer making Snuffers,"
Last summer. The website I posted still shows them.
The new ones are made from a UV resistant material, and should hold up much better. My spin goes in and out like clockwork now. 🙂
MN3 wrote: [quote=ropewalker]I got one for my F18 from Barefoot Studio. I'm sure they could make one to suit.
I am fixing the snuffer on the F18 HT that I am sailing. Apparently years of use had worn grooves into it causing the spi to hang. four layer of epoxy resin and a dremmel. I'm planning on painting it with truck bed liner paint to stop the abrasion from the lines, but maybe a new snuffer is in order....
if it's not too late: i would suggest an epoxy additive to add low-friction exterior coating with increased scuff resistance and durability.
like west system
420 422 or 423
https://www.westsystem.com/the-105-system/additives-pigments/
flightlead wrote: I wish I had seen your post earlier, but I guess I will see how the ten dollar shaker can paint from Home Depot holds up out on the water.
if you see wear, you can always just sand down a little and add a top coat of epoxy with the additives in the future
tigerberard wrote: anyone have a snuffer they would like to sale, hobie 20 450 sq foot spinnaker. Or a furler set up.Edited by tigerberard on Apr 09, 2019 - 05:35 PM.
Where are you located? 3' I have pole and hoop setup for sale...just needs to have a bag made. It fits a Mystere 6.0 so I'm sure it'll work for a Miracle 20.
- 6,611 Online
