what is "Soft Hull"?
I see this quoted frequently. Does this refer to a delamination of the glass composite, or some other fiberglass issue? I am assuming that there is little to no wood backing or forming in these modern (post 70's) hulls, hence it would likely be a resin / cloth disassociation issue?
Thank you for the input.
Posted : August 23, 2012 1:18 am
That is pretty unusual, usually you will see crazing, cracking and leaking before it gets that soft. Unless someone painted over it. Soft spots are insidious in the foam laminate hulls because if the core and backing are delammed, you won't see anything on the hull itself. Until of course you put your hand through it...
Posted : August 23, 2012 1:53 pm
Forum Information
- 6,748 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
