Bow tang broken broken !
Last weekend we were just about to set our spi (16-18 Kn Wind..) when the leeward bow tang snapped. Only crew standing in trapeze no really harm done...
Ashore I checked the other one which showed cracks as well.
Intend to replace both - after all the lasted > 2 decades <img src="<>/crazy.gif" alt="crazy" title="crazy" height="15" width="15" /> But friends told me this seems to be rather
common
for Hobie 16 with spi. By the way: original Hobie so only approx 17 m2
Anybody suggestions? Should I replace them just out of precaution and when yes how often ? Must admit still sailing at least March - October and do fancy some more wind <img src="<>/laugh.gif" alt="laugh" title="laugh" height="15" width="15" />
After all those years and regular crewing on other cats (F18) I still think nothing beats a Hobie 16 <img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" />
De even consider replacing the bow tang by some other device but have not worked something out yet
Will try to upload picture later
common
2 decades? Most things don't last two decades!
Add a higher load spinnaker to a 20 year old boat with directional loads not designed into the tang too... No wonder they think it's common.
common
Add a higher load spinnaker to a 20 year old boat, with directional loads not designed into the tang... No wonder they think it's common.
No corrosion or damage visible - just broke. Cutting edge showed nothing. Making it very difficult to predict when replacement is necessary !
Do agree the spi is european addition and although it's a relatively small (17 m2?) one it adds even more fun to Hobie 16 sailing ...
However did some research and found this breaking bow tangs more often happening than expected - also on Hobie 16 without a spi - even on a Wave recently.
So my remaining questions are:
should I replace the parts (both simultaneously of course)just out of precaution and when yes what seems to be good interval period?
Any alternatives available? Custom made stainless steel strip with 2 holes would do the job, bow tips have been reinforced with special
shoes
already. On the other hand: it is a known
weak
spot now. Who knows what can happen otherwise?
Just for information:
I found replacement bow tangs which are at least 2x thicker ! I'll replace both items just as precaution. <img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" />
Fellow H16 spi users at our club and also nearby club take same action - also on Wave with spi!
[will upload pictures later]
And now for something completely different:
Although saling with spi some years now I have just recently been told my spi doesn't open up aft as it should. <img src="<>/confused.gif" alt="confused" title="confused" height="15" width="15" />
Did some test by moving the block to aft. About mid tramp gave amazing improvement: better control, speed and able to sail higher !! :DCan start using spi sooner now.
So still learning but occaisionally you need some help. <img src="<>/blush.gif" alt="blush" title="blush" height="15" width="15" />
By the way: seems newer original Hobie spi is cut more flat so does not need moving of the blocks to aft ??
- 3,133 Online
