Hobie 16 Jib Cars...
Hobie 16 Forum
2
Posts
2
Users
0
Reactions
2,068
Views
Does anyone have a used set of Hobie 16 Jib Cars that will fit the standard external track from 1985? The plastic rollers within the old blocks have cracked. Thanks...
Jeffrey
horn.jeffrey@medstudent.pitt.edu
Posted : September 14, 2004 9:32 pm
I had the same problem. I cut off the old blocks from the Traveler car. I used Harken 40mm air blocks. You can get them with becket or without(lower profile by tying jibsheet through center) Pick up the block spring to keep it upright when the line is slack. The line runs smoother through the air block then the standard jib block
Posted : September 15, 2004 8:50 am
Forum Information
- 3,322 Online
Our newest member: wqaz
Latest Post: Hobie pearl / tiger mast needed
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
