Main traveler removal
You need to drill out the last 2 or 3 rivets in the track, which will allow you to lift it up enough to remove and replace the traveller car. Be careful only to drill out the head and not enlarge the hole. Then replace with countersunk rivets. The post below gives some hints on what to do to re-rivet the track back successfully.
http://www.catsailor.com/forums/sho...
Posted : October 26, 2004 8:19 am
Forum Information
- 3,298 Online
Our newest member: wqaz
Latest Post: Hobie pearl / tiger mast needed
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
