Mainsheet blocks
Hi Folks:
I have a few questions about the mainsheet systems that you are using on your 16’s. I have the old Seaway 5:1 and it’s seen better days. I want to upgrade to a new system this spring. I sail alone 90% of the time, don’t race in sanctioned events, and I have young teenagers that want to learn to sail and have not been strong enough to handle the Seaway 5:1.
Questions)
1)I have looked at 2 systems – the Harken low profile 6:1 from Catsailor (thanks Rick!) for 258.00 and the Harken Carbo Air system at $339.00. Is there a big difference between these 2 systems? I understand the more expensive system is load sensitive, and I have seen it in the store. Is it worth the extra cash?
2) I believe the 6:1, 7:1 and 8:1 systems use the same base unit (H194 or the Harken 2632) with beckets or blocks attached. Should I purchase the 7:1 or 8:1 system? (only 6 or 7 dollars more according to the adds in Catsailor?) Can you remove a pulley from a quad unit to make it a triple, or do you have to purchase a separate triple block if you want to go back to a 6:1?
Thanks!
Mac
6:1 is all you will ever need on the 16. Going with more purchase makes it too hard to sheet out.
Get the H194 lower and the Carbo upper H2640. Standard on new Hobie 16's.
H194 Harken List: $173.25
H2640 Harken List: $85.20
We do not recommend the Carbo ratchet lower. It is a PITA to adjust the jaw angles.
how would the line run with this? I am confused because I would love to increase the purchase on my 6.0 (6.1) but don't have any beckets on the blocks now and am not interested in spending 400$ to get new blocks.
In other words, to have a convertable 6:1/7:1 the upper (triple) block would need to have a becket. Add a standup block, mounted through the hardware that attaches the main sheet cleat, to your lower block. Your cleat is on the bottom, you add the extra block on top of the "plate" that supports the cleat. You're spending for an upper triple w/becket and one small block only.
Another option is the new "carbo" triple as the upper, and instead of buying with a becket, run the tail of the main sheet through the hole in the center of the blocks and dead end, in effect same as w/becket, but maybe a few more bucks.
Matt,
Are both the ratchmatic and the ratchet carbo lowers a pain? What makes them harder to adjust? Isn't it a case of set it and forget it?
I am looking at getting the ratchmatic system with beckets on both top and bottom with tripple on top.
http://mauriprosailing.com/Merchant...
And
Sam
I think the Ratchamatics are awesome myself and use them on every boat I have had since they came out.
On my F16 I am using the 8:1 Ratchamatic with 1/4
mainsheet. Sounds small,but with the 8:1 purchase it is easy to sheet and it also runs out very well when you ease the sheet.
I know in days of yore, we may have used as large as 7/16
line, and for sure 3/8
But with the new advanced blocks it is really not necessary and smaller line works really well.
I even use 1/4
on the Wave. Great for the puffs and when wheeling around the weather mark. Others are having to pull their sheets through the block, while mine just flys out and the sail is set within a boat length for downwind.
Rick
The jaw angle adjustment on the original ratchets is far simpler. They have not found a way to do this on the carbo version. Maybe not as big a deal if you set it and forget it, but I like to change the angle for some conditions. If it is really blowing, I may want to get the blocks to release easier, so place the jaws higher. It is personal preference. I see no advantage to the carbo lower. That is why we use the standard triple lower and carbo upper in combination.
The ratchamatic lower is a nightmare! My son had a new 16 at the Carnac Eurocat regatta last year and spent the whole event trying to get the cleats at the right angle, got all stressed about it and didn't enjoy the event at all!
We spent some time with little plastic wedges and have eventually got it right now [one setting for all winds]
For some reason, this flashy/expensive piece of kit does not hold the cleat at the right angle.
Rick, are you talking about the hexaratchet that Matt is talking about
http:/
or the ratchmatic
http:/
or maybe something completely different like the carbo ratchet?
http:/
It seems that the breaking loads on the carbo stuff is a fair bit higher if that is of any value.
Sam
I like the adjustments on the 194 Hexaratchet triple...
![[Linked Image]](http://www.harkenstore.com/images/194.jpg)
You just ease out the screw in the slot on either side. Make the adjustement up or down and re-tighten. It is easy to see you are in the 1 to whatever position.
I do not like the adjustment on the 2630 Carbo triple...
![[Linked Image]](http://www.harkenstore.com/images/2630.jpg)
You have to back out the center screw to get both sides of the system out of its indents. You then move and re-seat the side plates. Then tighten the screw. There is no good way to see how far you moved it and it is a disaster if you unscrew the thing too far.
The 2141 would be even harder to deal with.
On the strenght end: I'm no weakling, and when it really blowing, and I've been out a long time I struggle with sheating. I have a 6:1 harken system w/ 3/8 sheat. Most of this is probably because I tend to go out in heavy winds, and it all on lakes, or the Mississippi. Lot's of puffs and I never cleat the main. Just food for thought if you concerned with the strenght issue.
Ok, the 6:1 or 7:1 is probably all you need for purchase, but what about the breaking strenght of the blocks them selves?
model h194
Shackle pin dia. (in) 1/4
SWL (lb) 500
Breaking strength (lb) 2000
Use with 004 - 5:1 / 048 - 6:1
verses the h2630 at
SWL (lb) 1800
Breaking strength (lb) 4500
Holding power w/180 degree wrap 50 lb (23 kg) 10:1
I assume the SWL is the swivle breaking strenght?
Is this an issue on a h16?
Sam
SWL = sustained working load if I remember correctly. You can really put the blocks under these loads and over whithout worrying about breaking them. Maximum breaking loads are typically alot higher. If passed swl you'll just wear the blocks down quicker which is still many many years. In effect SWL doesn't mean much.
Wouter
Safe working load limit is more precise but the concept is the same. The 2000 lb breaking point has been derated by a factor of 4 to give you a "safe" capacity of 500 lbs.
What I have yet to figure out is if I could lift an 80 pound sack of cement with just a line in my hand. If I can, then a 7:1 would exceed the swl but still come nowhere near the breaking strength.
Ok - so what are most of you using for a mainsheet - I've read 1/4", 3/8" and 7/16". I have 7/16, but if I buy a 194 with a 2640 upper block the max line size is 3/8". Will the 3/8 line run through the 2640 freely? What line type do you recommend for the average sailor?
I'll throw another size in, we just purchased a 5/16" main sheet. Use a line designed specifically for main sheets. Some of the low stretch (stiff) lines will not wrap around a smaller diameter block as easily as a softer version. In other words it is too stiff to properly grip the blocks. I think you'll find the advantage of easier use in reducing diameter only. Be very careful (or ask an expert/retailer) before purchasing a "high tech" line.
Sorry for no "specific" answer, there are a lot of different brands and "families" available.
Yeah, it's the little black slide on the side.
Mainsheets:
New England Ropes - Salsa line
New England Ropes
8 mm = 5/16"; 9 mm = 3/8"
Maffioli Swiftcord
You can buy this in a number of places, but Hall Spars USA is the US distributor. Hall Spars
OK Rick and Matt - does the 2630 have more holding power than the 194 with the ratchet on? I keep reading about it having a 10:1 holding power. The same with the upper blocks -2640 vs the 153 - the 2640 looks lighter with a lower profile, but is there any difference in the holding power of these blocks?
Ratchets have always had an on and off switch. Generally you use the ratchet in higher winds. You turn it off for better sensitivity in lighter air. If you are sitting on the rail, the sheets may not pay out fast enough, so you turn it off. In higher winds the ratchet helps hold the sheet, but still pays out if you let it go.
I don't think there is a difference between one Harken ratchet and the next model, but more purchase will have more "holding power".
Just to clarify, when you have a 6:1 purchase if you pull on the line with 100 lbs of force the system exerts 600 lbs of force on the sail. I know this is obvious but you never know questions people will not ask.
So, the "holding power" everyone speaks of is really what you feel on the line.
Also, the shape of the first pulley the line goes into will determine how much tension you need to keep on the sheet to hold it into place with the ratchet. As well as the torque the ratchet mechanism is rated for. I know on my system (I don't know the part numbers) the first pully "grabs" the line a little bit so I only need to keep enough tension on the line to seat it in the pulley when the ratchet is on.
I just wnated to make sure everyone is talking about the same thing.
Thanks Matt and Nick - Let's say you are out on the wire in a blow. Will the carbo unit (2629) be easier on the arms in terms of holding the sheet and not cleating in, than the Hexa (194) block? Harken claims the carbo has 10:1 holding power @ 180 degree wrap. I haven't seen any claims for the 194, but it may just be a marketing ploy for the newer carbo blocks.
As far as I know, the design of the ratchet sheave is unchanged, so the "holding power" of the sheave should be the same. The benifit to an increased hold would be up for debate and personal preference... not critical. The difference is more one of weight. The Carbos are lighter. The critical difference to me is the ability to make adjustments to the jaw angle. The carbo ratchets are a pain is that respect.
- 6,285 Online
Thanks Matt and John - This is exactly the info that I need.
