proper mast angle
2 Users
(@_removed-account)
Four Star Admiral Registered
[#8709]
i don't know if it is called rake or something else, but my mast seems to be leaning way back. is this correct or should i tighten up the shrouds and forstay to get more of a 90 deg. angle versus the hulls?
Posted : July 10, 2001 11:43 pm
Matt M
(@matt-m)
FAT CAT
THE MAST ON A 16 SHOULD BE RAKED BACK AS FAR AS YOUR SAILS WILL ALLOW.
WITH A SNUG JIB HALYARD TENSION, SHEET IN THE MAIN BLOCK TO BLOCK AND ON THE BEACH THE TOP 2-3 PANELS SHOULD BE SLIGHTLY HOOKED. MOVE THE SIDE STAYS UP OR DOWN AS REQUIRED TO SET MAIN.
MAKE SURE THAT AFTER THE MAIN IS SET THE JIB IS ADJUSTED SO THAT IT IS SNUG EQUALLY ON THE FOOT AND LEACH WHEN IT IS BROUGHT BLOCK TO BLOCK.
SAIL FAST
MATT
Posted : July 12, 2001 10:54 am
