Rake/Tiller-Tug question?
Hello,
I am currently running an
old style
H16 (older mast and rudder setup). I have the new style (shorter) shrouds and I am hoping to hear from experienced sailors on which chain-plate hole to use on the side-stays in order to best manage the tiller-tug issue.
So Far, I am pinned at the third hole from the top and I find the tiller-tug excessive enough to take the fun out sailing after about one hand-cramping hour.
Since I must trailer my boat, and setup at a boat launch, I rarely have the luxury of simply going back to the beach to re-rigg the boat. This is why I`d rather
just ask
Any advice?
Dave,
I am not sure about the mast rake vs. tug (weather helm) on an H-16 but have always understood that the rudder rake will have a big effect on it. It can be adjusted by setscrews in the rudder casings and by then adjusting the latch that locks down the rudders.
Generally, as you rake a mast back it moves the center of effort on the sail further aft. In a centerboard boat, the center of resistance is near the board so the C of E and the C of R make a turning moment trying to turn the boat into the wind (as long as the C of E is aft of the C of R). When the C of E is foward of the C of R, the boat wants to turn downwind, a lee helm, and a dangerous boat. I don't know how to judge the center of resistance on an H-16 which uses the hulls alone to prevent side slip. I imagine weight balance would affect it. I also sail a catboat which is a monohull which is notorious for strong weather helm. In that boat it is possible to adjust weather helm by adjusting the angle of the centerboard which changes location of the C of E.
Howard
Thanks Howard,
The mast rake certainly does affect tiller-tug. However, the older H16 casts do not have a set screw to rake the rudders under the boat. Therefore, all adjustments have to made with the mast in order to reduce the pull at the helm. Eventually, I`ll either upgrade the entire rudder system, or re-drill the rudders while retro-fitting a
set screw
setup myself. In the meantime, figuring out which holes to use on the side-stay chain-plates are my best bet.
Hi Captain, A prescribed setup for the
right
hole on the chain plate is not possible - too different are mainsheet systems, tolerances and other factors (racing vs. recreational sailing).
In a way you already answered your question. You have created a good amount of mast rake resulting in unreasonable wetherhelm - you have described what could be done to compensate for it (rudder rake adjustment).
The limit for mast rake is pretty much when upper und lower mainsheet block touch. This is a setup that you could adjust anywhere (e.g. in your driveway on a still day). The rudder rake adjustment is more difficult - especially on a non-adjustable casting. You mentioned the re-drilling option (difficult since there is a lot of guess work and you have only one chance to get it right) or the upgrade to an adjustable casting ($$$)
Patrick
Find someone that's already gone through finding the right place to drill the rudder and see if you can use their rudder as a pattern for yours.
Dave: Hobie sells a retrofit kit to adjust your rudder rake.
(or at least the did)
You can change the feel some with the mast rake, but not enough to make the weather helm go away. I cut out the fixed stud on the upper casting and machined out the hole and then used a 5/16" ss nut and bolt as a way to rake the rudders on my old 14. It worked well. Drilling the rudders is also critical.We have a couple of guys with jigs around here that get a lot of business as people pick up new boats.
As was mentioned if someone has a boat with adjustable castings and are happy with thier helm you can use that as a starting point. I sailed an old boat last summer without the adjustable casting and an old set of lexan rudders. I don't know how we used to do that. The boat feels terrible. You have to put your weight way back and sheet out just to make the boat go without cavitation.
Why not stick with the original length on the shrouds and forestay? When I need new wires, I just have the sail shop custom make new ones. The price might even be cheaper than Hobie's new parts. Mine were. And it was a heavier wire.
Of course, if you want the extra rake...
- 989 Online
