rudderd locking mechanism
Appreciate any comments you may have.
Cheers, PT.
Do a Google search for HTS-2000 brazing rods. Never personally used the stuff, but for a small repair like that, they sound like the ticket.
Sorry for the late response.
When I did it the first time I had never seen the inside of the factory adjustable arms. When I installed the plate and tightened the bolt, I relized that it needed a spacer of some sort, so I just stacked a few SS washers until it was standing proud enough to engage in the cam.
It worked perfectly and it was only when I bought a newer boat that I saw the cast-in rails inside the arm.
I have been pondering this for a while because the local sheriffs camp has about 20 16s and 14s that we are helping with. The rudder systems are horrid. Mostly old non adjustable castings. I had an idea for a simple modification that I would like to run by you guys. The old castings use a ss tube in a hole through the upper casting that is flared on both ends to hold it in place. What if I drilled that out and drilled/ filed adjacent to it to make a slot. Then replace the tube with a 1/4-20 bolt and nut with some star washers for grip. This could be adjusted in the newly made slots to get a proper lock down. The slot would only have to go towards the cam since these old systems are always loose.
What do you guys think?
That certainly sounds doable and easier/cheaper than the old EX Raker. A few thoughts (that you may have already considered):
If, like many old boats, there's excessive slop in other parts of the system (gudgeons, rudder pins, holes in castings for the rudder pins), this mod may not be real helpful in and of itself. It's hard to describe well in words, but, if there's slop elsewhere and the new slot is wide enough, it will likely be possible to slide the new bolt so far forward in relation to the pin/sister screws on which the cam rides that the cam will not have enough clearance to rotate properly. (This can occur with the modern adjustable system and the EZ Raker as well.) If adjusted with the rudder locked down, the cam will be bound and not rotate up; if adjusted with the rudder up, the bolt will be blocked before the cam is rotated all the way down. In such case if the bolt is slid back enough for proper cam rotation, the rudder will likely still trail back due to the excessive slop elsewhere causing unwanted tiller load. I guess the bottom line is that this mod cannot remove excessive slop located elsewhere in the system. While the rudder should lock/unlock better than it does now, this mod may not fully achieve the desired result without new rudder pins and/or gudgeon/casting bushings.
The length of the new bolt that will be inside the casting should not be threaded (for increased shear strength and minimization of damage to the cam).
This sounds like a lot of work, but for a great cause. Perhaps a local machine shop would contribute (free or reduced cost) services toward all of the needed mods in exchange for some public recognition?
I believe your idea has a lot of merit and would like to hear others' thoughts.....maybe you should revive this old Hobie Forum thread?: https:/
Good luck and please let us know how this works out!
I think I can cobble together a jig to hold the upper casting on a drill press in the right orientation. I think 1/4†of adjustment is all that will be required. Drill one hole next to the current hole and then use the drill bit like an end mill to create the slot. Of course this will not solve other worn parts but it will allow a bit of adjustment. If I get the ambition I’m going to try this on an old set of upper castings I have.
- 3,131 Online
