Taking Hobie16 Apart
I'm trying to take my Hobie 16 Apart, so that I can Paint it in my garage. (I live in Canada, and it's only 9-13 degrees Celcius. I need to have at least 18 for it to dry well.)
When I took the Bolts out of the corner posts, i tried pulling them apart, but it wouldn't budge. Is there anything that will get rid of the dried up silicone that is keeping my boat together? Or should I just wait until summer for it to be warm enough because it's too much of a hassel?
Some folks glue the pylons...it may be difficult to get apart. A hair dryer is a good idea; it may be better to get a heat gun. Some epoxies may not turn loose with heat...at least with the amount of heat you can apply without damaging the fiberglass. If you cannot get it to turn loose, you probably should consider leaving them alone, and refinishing with the frame attached.
David
Yeah I tried everything under the sun and I couldn't get my rear cross bar off, So I drilled out the rivets ine the corner castings and removed the beam between the castings instead of taking the castings off the pylons. What a nightmare! But it all went back together nice and tight. Note I did have to pry the hulls apart, oxidation got the best of the fittings. Good luck!
- 3,318 Online
