Building the DS12
So the first lesson is up. It will propably be rather boring for most of you, but if we combine our ideas we will maybe end up with a good manual how to build a DS12.
http:/
<img src=
You will need 6 sheets of 3-4mm Okume or Gabon ply for the boat, and another one if you are thinking of making the mast yourself, guess there will be a drawing for that later if everything works out all right. 4 meters of alu tube for the beams. Then you will need some epoxy a wild guess 5 kg to make hulls, rudders, foils and mast.
Some micro fibres, foam blocks, E- glass for the deck, and a good quantity of carbon for the mast.
You will have a bill around 1000 euros for the material maybe less.
Sails and battens you can get from Singapour for about 250 euros.
I will start to post material used, costs and number on hours spent on the cat on my blog.
So here comes lesson 2 and 3. About 9 hours of work so far.
http:/
Hopefully you have done your homework, here is another one:
http:/
Lesson number nine is up. Will be sitting on a ferry all Monday and hopefully get some time were there is not a lot else to do so with a little bit luck there will be more after that.
http:/
- 7,092 Online
