Carbon cloth(uni and biaxial) and hard foam sourci
Hi dacarls
Monel is what a lot of riggers use over here, including Greg Goodall who put me on to them. I have just brought a heavy duty rivet gun, with handles like a swaging tool or bolt cutters, makes it alot easier and was about the same price as a quality regular hand rivetter, it was cheap, but its doin the job for the moment, when I went looking for one I expected to pay 2-3 times what I paid.
Regards
I get carbon fiber fron Soller Composites (603 934 10290),
peel-ply and sealant tape from Fiberglass Supply (509 493 3464) and mold wax and mold release from Sweet Composites.
Also if you want glass at a good price call www.thayercraft.com
I am in the process of building an A-Cat and am using their
Unidirectional 6.0 OZ cloth.
for cloth and resins www.aircraftspruce.com for foam i use www.flyingfoam.com what the they call
spyder
foam is the hardest. bob will even cut it to exact specs on his cnc machine. I made a set of daggers for a viva 27, 8'4" tall. bob cut the cores. i used the knitted rutan unidirectional times about 10-15 layers.
Are there any aerodynamic advantages to
foil shaped
spreaders compared to regular tubes, in real life?
As for the diamond wires, a notch cut in the ends and then two holes for SS safety wire to hold the diamond stay in place. The tip of each spreader has a block of ebony, which is very hard stuff and this spreads the compression load out over the hole surface of the spreader.
I do not have any numbers to support this, but I don't know how an airfoil shape could not have
over a round tube.
For those home builders looking to find out how the
big boys
do it.
http:/
- 7,099 Online
