Vacuum Pumps
The vacuum pumps that home builders use show an amazing variety and range of capability. Everything from aquarium pumps to vacuum cleaners. A professional outfit at retail prices can easily cost $1000 US. That’s a steep price to pay for an amateur builder. So somewhere between a $1000 pump and your home vacuum cleaner there must be a rig to get the job done without bankrupting the builder.
The two important things are that a pump be reliable (if it quits during the cure you are screwed) and it has to have enough capacity to tolerate minor leaks in the bag or mold. Theoretically, if a bag is totally sealed, a very small pump is all you would need. Real life is very different. Even if you do a complete dress rehearsal with the bag and pump before committing to wetting out the reinforcements, and the bag proves to be tight, there are still things that happen during the actual lay up. For instance, a drop of wet resin where the bag seals to the mold will prevent the sealant tape from sticking and will cause a leak. There may be a minor leak in the pleats and folds of the bag that is nearly impossible to find. For these reasons, some significant pump capacity is needed – the more the better.
I’m sure there are a lot of opinions on this but to vacuum bag something the size of a Tornado hull side; I would recommend a pump of a least 4 cubic feet of air per minute. This equates to around 1/3 horse power which is a little bit more than the average HYVAC air conditioning service pump. There are oil filled pumps that can develop more vacuum than dry rotary vane pumps but they are messy and require a lot of maintenance. I have acquired several pumps over the years, a couple of Gast 1/3 horsepower rotary vane units, a one horse power (14 cubic feet per minute) Gast vane pump, and a two horse power oil filled vane pump (16 cubic feet per minute). Although most pumps can produce 27 to 29 inches of vacuum, 20 inches will produce good quality parts. If you can’t get above 15, the quality of the part will definitely start to suffer.
Finally, this brings us to the issue where to buy a pump. I swear by Ebay. If you search under ‘vacuum pump’ there will be a hundred or more hits. The 1/3 horse power Gast units are common in computer rooms and machine shops. A unit in excellent condition can be had for around $100. They retail for around $400. My 14 cubic foot pump cost $180 on Ebay and was brand new surplus. Retails for about $800. So, the deals are out there if you look around a little.
When I set up my vacuum pump (home made) I also bought a vacuum generator as well as a backup. In case your main pump fails you should have a backup
plumbed
and ready. http:/
While I have never had a problem, it's nice to know that I have a spare in the shop. <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
When I first started looking for my main pump last year I went to a dairy farmer friend that was just in the process of selling their farm.
I asked if they wanted to sell one of the pumps they use to milk the cows ( a roots vane type) but another farmer had taken them earlier in the week <img src="<>/frown.gif" alt="frown" title="frown" height="15" width="15" />
Yes, it's great to have a spare set up. I think builders that take on big vacuum bag projects are really compulsive gamblers. Half way into the layup with a thousand bucks of carbon and a bucket of resin with the clock ticking you start to wonder 'what the hell am I doing'! But if the result is a quality part that you know is better than 90% of what professional builders make - it's worth the stress.
I'll have to say I don't feel the pressure. The epoxy I use will sit in the pot or roller tray (10 oz. at a time) for one hour before I start to worry about it. It takes me about 90 minutes of
wet work
to layup a side of an A Cat hull. Most of my time is spent in the prep. work. And checking the bag before I turn up the heat. Once every thing is good it goes to 130/140 and six hours later I turn every thing off and walk away for 36 hour, then pop out the part. I used to use West Systems and always had to change rollers and brushes and mixing pots because the resin would start to pop off to quickly. But back then Gougeon only had two flavors
fast
or
slow
We probably do a lot of the same things ahead of time to minimize
open time
during layup. The reason I was feeling some pressure was that my layup was a 34 foot tiamaran half hull. There were 4 layers of reinforcement - Kevlar, carbon fabric, carbon uni, and glass. That's about 6X the size of A-class. I used a Polyamide curing agent with a 90 minute pot life at 65 deg F. But I was usually working in 80 to 90 deg F. The part took about 6 liters of resin so I would measure out shead of time three batches of epoxy/hardner and mix them as needed. Once the epoxy is out of the pot an into the fabric it takes a lot longer to begin cure. Do you have any time saving ideas to help Mike with his 20 foot trimaran layup?
Since I am using a mold there is probably not a lot of crossover.
If he does use the
band of epoxy where the seal tape
(another thread) he should cover everything from that band outward with blue painters tape. I put down my
tacky tape
and then cover it as well as most of the flange before I start the wet work. Then after everything is in the mold (glass, core, peel ply, release film, and breather) I pull up the blue tape and every thing is
dry
and clean.
I do the same thing to protect tacky tape during layup. I also cut all pieces of glass and carbon out to size first. Check them for fit on the mold then number all from forward to aft in the upper aft corner. They are stacked on one end of the mold in the reverse order of the finished part. That way it's very hard to get mixed up and place something backwards or upside down.
My last boat was male mold using a caul plate to mold the outside skin. The caul plate is a flat plate of 3mm PVC sheet with a glossy finish. It's outside edges match the male mold edges when vacuumed against the hull side. Treated with mold release before layup.
do some of you use an vacuum resevoir? [reverse of an compressor tank]
this guy did it [btw used an old fridge compressor]
see link [use bablefish translator or something- org. text is in dutch]
http://www.xs4all.nl/~ebb/kiteboard/html/handleiding/hl_24bou.html?page=eee
Yes, my pump has a four gallon reservoir and then across the shed from where the compressor and vacuum pump are I have a six foot section of sched. 40 pipe setup as a reservoir and it has three connectors on it. One fore a vacuum gage, and the other two connect to vacuum line to go to my bag.
I do not use a resvoir but aways install a resin trap to protect the pump. Can be made from PVC pipe and fittings. I have found it very useful to install a plastic ball valve in the vacuum line just before entry into the bag. That way you can control how fast a vacuum is drawn and stop the process if needed. For instance, if the bag is drawing down and you notice a piece of foam core or fabric is a little bit out of position, you can shut the valve and reposition it. Once a hard vacuum is drawn it is impossible to adjust anything. And, without a valve, you would have to go secure the pump and disconnect supply piping.
try putting the tacky tape on the bag first. place it one or two mm back from the edge. still use the painter's tape on the part, but the tape on the bag will cut down on the time the epoxy is 'out' before the bag is down. i have used both methods, the tape on the part and filling in folds and the tape on the bag. i did the first for about 20 years. after having used the second, i realize i wasted 20 years.
Putting the tape on the bag instead of the mold is a great idea. I'll try this next time. How do you handle multiple vacuum ports for large parts? If there is more than say ten feet between the port and the far end of the bag, the vacuum at the far end can be too weak. I usually put a 1/2 inch PVC pipe inside the bag with 1/4 inch holes drilled every six inches or so. I seal the pipe in a pleat in the bagging film at the edge of the mold. To prevent any distortion of the part, I tape strips of 1/8 inch plywood about 2 inches wide along the length of the pipe. The pipe with the plywood taped to the bottom is outside the peel ply but inside the breather layer. Seems to work pretty well on hull sides and spar layups.
If you already have even small aircompressor you can build a very cheap vacuumsextaktor using this:
https:/
If somebody is interesting I can upload pics of my setup.
That's exactly what it is, to primitive for a lot of freaks...
Here i action making a ply/glass spar http:/
Ply/carbon http:/
And the next will be Foam/carbon
Dont drop out on us on your projects, I love seeing the pictures of homebuilt stuff! Foam carbon mast, now that is a _wildly_ interesting project. Also, you never told me how you made the mast track, or did you?
As long as it does the job and is cheap.. Who cares.
Where do you buy stuff like peel ply, vacuum tubing etc?
No intention to drop out. Peel ply well from the dressmaker or from your supplyer of epoxy, glass carbon etc.
Plastic tubing? For the bagging of spars just ask the guy who sell the Peel ply to give you some extra of the
tubes
he uses for packing the stuff he is selling you.
The blue tubing seen in the pic you get from the store where they sell pneumatic stuff (about 50 cent/m)
Buy a cheap stethoscope, the leak will sound like a freight train. With a little practice you can
see
the leak as the surrounding area will not be pulled down as tightly as the rest.
Ok, so I got a vacuum pump from ebay. An oil rotary thing, label says it pulls full vacuum (0.0001 tor), 2 cubic meters per hour.
Unfortunatelly the motor is 3 phase 380 Volts, 1360RPM. I only have 1 phase 220 Volts connection so I was thinking of replacing the motor with a 220v one. The motor is physically very easy to replace, it has a flexible coupling to the pump shaft and 4 screws securing it to the frame.
Question: what happens if I put a faster motor on it ? Say 2000-3000rpm instead of 1360rpm as the old motor. Will it suck more air per hour (faster) or will it fry the oil and the internals ? Also what type of oil to use with it ?
Thanks guys.
Regards
Well , did some reading:
you are expected to use only vacuum pump oil for vacuum pumps (imagine that). Unless you are a chemist don't put anything else in there if you care for the life of the tool and the final vacuum level.
Vacuum pump oil is graded for different types of pumps, different speeds and different vacumm levels, so it is tricky business, your manufacturer will supply those.
Also if you're in doubt about the oil you have - if it is yellowish or any other colour - don't use it. The good vacuum pump oil must bea clear/transparent.
Also Shell makes something that appears to be general use vacuum pump oil - SHell Corena V
- 5,058 Online
