Clevis pins are a pain
The two pins that hold the rear stays to the hulls are difficult to thread the split rings through (the old eyeballs aren't quite what they used to be). Is there some kind of quick connector that would be trust-worthy enough for this application (I did not see much at West Marine).
Posted : July 12, 2005 3:04 pm
Ring pins are the best and easiest to put in and remove. However, my son, for example, does not trust them much. So he uses cotter pins -- easy to get in when new, but after that they are difficult. And they have a good chance of snagging and rippping a sail.
Best to stick with the ring pins. They also can manage to come out and cause a mast to fall. So, I always tape all ring pins before sailing with electrician's tape.
Good luck,
Rick
Posted : July 13, 2005 9:25 am
Forum Information
- 6,961 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
