Rudder repair
(@hokypuk)
[#8192]
Is this fixable? It’s a Catyak and the fins where the rudder is bolted snapped off.
I had trouble with the pictures. They’re in the “rudder repair” album.
Sue
D0A71512-6F8F-4E50-9686-86B2C439AF79
7525AF2D-795D-4C4A-9C20-DE9C630CF44A
Edited by hokypuk on Jul 11, 2022 - 10:08 AM.
Posted : July 10, 2022 5:36 pm
tominpa
(@tominpa)
This is the only image I saw. Doesn't make much sense to me.
Posted : July 11, 2022 2:32 am
(@hokypuk)
Please let me know if I fixed the pictures. Thank you!
Edited by hokypuk on Jul 11, 2022 - 06:35 PM.
Posted : July 11, 2022 3:10 am
(@hokypuk)
Posted : July 11, 2022 11:30 am
tominpa
(@tominpa)
Maybe try hosting on Imgur and posting a link. A verbal description of your concern would go a long way.
Edited by tominpa on Jul 11, 2022 - 08:49 PM.
Posted : July 11, 2022 1:48 pm
(@rodgers)
looks like you will need to move the hinge down, or add a strip of material to the side of that flange. Then mount the hinge to the new piece.
link to a sceenshot of the transom
Posted : July 12, 2022 6:56 am
(@hokypuk)
Thank you! I don’t know what I’m doing… is the flange the plastic fin?
What would I use to fix it?
https://imgur.com/FnfjhAi
https://imgur.com/SbYxh22
Posted : July 14, 2022 1:26 pm
 gdog
(@gdog)
What I would do is remove the broken piece and glue it back on with west system G-flex. This is only to align
everything and use it as a spacer. Next go to a big box store or a metal supplier and get a piece of 1 inch wide
aluminum flat bar. put a piece on either side of the fin and either rivet or bolt it to the fin. drill through the aluminum pieces and bolt the rudder hinge back on. I probably would extend the aluminum high enough so
that you could also attach a piece to the rib on top of the hull. Where are you located? Maybe someone here is close by and could help out?
GDog
Posted : July 16, 2022 1:14 pm
tominpa
(@tominpa)
Image assist: Just put the URL for your image in between Image tags. Click Image in the reply menu.
Posted : July 16, 2022 4:13 pm
