Rudder repair
Is this fixable? It’s a Catyak and the fins where the rudder is bolted snapped off.
I had trouble with the pictures. They’re in the “rudder repair” album.
Sue
D0A71512-6F8F-4E50-9686-86B2C439AF79
7525AF2D-795D-4C4A-9C20-DE9C630CF44A
Edited by hokypuk on Jul 11, 2022 - 10:08 AM.
Thank you! I don’t know what I’m doing… is the flange the plastic fin?
What would I use to fix it?
https://imgur.com/FnfjhAi
https://imgur.com/SbYxh22
What I would do is remove the broken piece and glue it back on with west system G-flex. This is only to align
everything and use it as a spacer. Next go to a big box store or a metal supplier and get a piece of 1 inch wide
aluminum flat bar. put a piece on either side of the fin and either rivet or bolt it to the fin. drill through the aluminum pieces and bolt the rudder hinge back on. I probably would extend the aluminum high enough so
that you could also attach a piece to the rib on top of the hull. Where are you located? Maybe someone here is close by and could help out?
GDog
- 7,118 Online
