Tiller extension options
Hi All,
I have the new style rudders/tiller on my Wave, and have found that tiller-behind-the-sheet a little short. Occasionally I even use my feet to hold it.
What I would like to do is add a tiller extension, but the way the tiller bar must be raised up so high when raising rudders has me concerned about the hinge angle when raised. I don't want to break or stress anything.
I am also unsure of components to buy. I thought about just purchasing the Getaway parts, yoke, hinge, stick, etc, but that really adds up. Mounting is another question. Since the tiller is fairly high to begin with, should the yoke be mounted upside down, or on top but at a forward angle?
I don't think a extendable model like a hotstick is necessary, as I will not be trapping out. I think a cut-down stick will work.
Anybody have any thoughts?
Thanks <img src=
Jim
I am not sure how you feel about going with the cheap way out but an aluminuim paint stick works well and it makes it extendable if you need it. Also alot of the F16 guys use conduit.
Buy the connections and then just make the extension. You can even add a cool paint job.
Where are you located, I actually have two things that might help you.
I have a few extra of the connections that I would basically give to you for the cost of shipping, also I have an old aluminium extension that I managed to break, I had to buy a new one because it is now to short to allow me to go all over the boat. But for you it would work.
It still works fine and the broken end is covered by duct tape right now but you could add some kind of grip.
If you are interested in any of this just send me a PM on here.
HI Jim,
Here is the part you need: http:/
You cannot mount it under the tiller bar as it won't swing from side to side.
On top would also cause problems as you have pointed out. So, put it on top but angled slightly forward, enough that allows the tiller to lay on the deck without stressing the Yoke Assembly.
In doing so, howeever, you will not be able to drop the tiller off the back of the boat (which is good) as that would cause the same stress you are concerned about.
For the actual tiller, just go to a local hardware store and get an aluminum tube the size you want.
Good luck,
Rick
Thanks Rick. That part and the hinge, all I will need to find is a lightweight pole of some sort.
I am guessing that the lightest pole I can find would be best, to minimize any stress to the crossbar, particularly when dropped off the rear as you pointed out. That is why I will try to avoid an extendable. I found carbon fiber tubing, but that stuff is pricy!
I will post results once I do it.
Appreciate the tips!
I have the wings or whatever on my wave. I got a cheap $5.00 windshield cleaner that telescopes, cut it off and drilled a hole in the crossbar and mounted the thing. When i sit on the backrest i can extend the tiller. when i come on the tramp shorten it up. Cheap and effective.
For tiller extensions on old style tillers.., or even the new rudders, take a look at the following article. This was the system used on Shark Cats for many years and maybe still on many of them.
http:/
Rick
I just made a (double) tiller extension out of PVC conduit using a
flexible elbow
in the middle, clamped to the middle of the tiller crossbar. The result is similar to the arrangement in Rick's link, but each side is independent.
I used 3/4
conduit because it matches the crossbar diameter, and 1/2
seemed too flimsy. The
flexible elbow
is a single item, next to the rigid conduit elbows on the store shelf. I used two pairs of the plastic conduit hangers (side-by-side & back-to-back) for the clamp, and I put solid caps on the ends. I paid about $13.00 total for all the components, including nuts, bolts and star washers at Lowe's.
I made each side 4 feet long (sticks out 1 foot beyond the tiller arm) and put a ball-bungee on each side, to hold the un-used half snug to the crossbar (out of the way). The
flexible elbow
includes threaded couplings, so you can unscrew the poles for storage (or IWCA regattas, where extensions are prohibited).
With the short EZ-Lock tillers, I really felt restricted to the back corner of the boat. Now I can move up or hike out as much as I want.
Wow, that is a pretty hefty-looking tiller! Seems like overkill for such a little boat that has very neutral helm.
One comment:
An advantage of the new rudder system with the tillers higher and back farther is that the helmsperson can also get back farther (back UNDERNEATH the tiller) on a reach, and therefore go faster and keep the bows up. Your extension will effectively be a bar that prevents you from doing that.
Actually, there's still plenty of room to get underneath it, and the extra foot sticking out to the side lets you hike out flatter once you're back there. The flexible elbow lets you swing it wherever you need: up, down, fore, aft. You can always just push it out of the way, if you don't need it.
But you're right about the
heft
. I could have gone with the 1/2
conduit, but I liked the feel of the 3/4
, since it matched the crossbar. The extra weight does tend to pull down on the tillers when they're raised, however.
Very clever! I like the doubled C clips to attach to the tiller. I would have used hose clamps but your idea solves any rusting issues and the need for a rubber piece to keep the hose clamps from scratching the tiller paint. Is the flexible section in the middle just flexible conduit? uhh are you an electrician?? ;~}
Hey, check this out! The Indy Car teams stole my tiller extension idea!
I never even realized an Indy Car needed a tiller extension, but we saw these in several garages, when the Wave Midwest participants went to the Indianapolis Motor Speedway on Friday. The mechanic working by the right front tire is a member of the Eagle Creek Sailing Club.
Okay, well maybe it's a part of the measurement jig they use to set up the cars...
Rick
I really like IndyWave's approach, but I took the more traditional looking tiller route.
Basically mimics the setup of that on a Getaway, but at a fraction of the cost.
I have been sailing with my 'home-made' tiller for a few weeks now, and I can safely say it is worth the effort. I love having the ability to sit in different locations, ie farther foward when running, or light air sailing. One comment I will add, when sailing in really wild wind conditions, say where you are sitting pretty much under the tiller to keep the bows up, then you may opt to strap the tiller ext in place and just use the tiller as it was intended.
But my concerns about 'stress' on the crossbar seem to be unfounded. It works out great. The only issue I have is when the rudders are raised, the tiller extension must be flopped off towards the stern, ball lock bungeed as was suggested, or left to rest on the rudder housing. If not, the hinge tends to bind only slightly on the crossbar causing some minor scratching. This is due to the extreme difference between the up vs down postion of the crossbar.
Not a biggie though.
I began by mounting my crossbar upside down, see the pic, brought the rudders down, and postioned and drilled the hole for the hinge 5 to 10 degrees forward.
Again, here is a materials list for those who wish to try:
Hobie standard hinge p/n 10532010
yoke p/n 3205 ($16 for these two parts)
soft grip 3206 (from page 23 of cat, fits perfectly on the 1/2
cpvc)
(if you want to save the $9 of this Hobie grip, then opt for a 30cent CPVC cap <img src=
60
length of 1/2
cpvc (I bought mine at Lowe's for less than $2) leave it at this length,
3' or 4' length of 1/2
wood dowel (sanded slightly, and pounded into pvc to stiffen)
a little urathane glue like 'marine' Goo to glue on the grip.
Here it is with rudders up ![[Linked Image]](http://i287.photobucket.com/albums/ll136/jimdraw/wavetramp001.jpg)
And rudders down while underway... ![[Linked Image]](http://i287.photobucket.com/albums/ll136/jimdraw/wavetramp004.jpg)
- 4,692 Online
