Adding a Jib to a Mossie
Hey there Gary,
Does your boat already have a sloop bridle? Most boats do, but there are a few cat rig boats out there that have a twin forestay, or a high bridle setup, to reduce the load on the hulls.
This (http:/
The jib is usually zipped to the fore-stay, so you would need to add a block somewhere near the top of the fore-stay for the jib halyard.
The jib blocks on most of the boats are shackled to some loops of dyneema on the tramp. This way the jib setup can easily be removed when sailing solo, and the jib angle can be adjusted by shackling to different loops.
http:/
Check out the pictures in the photo album below to give you some further guidance.
http:/
Good luck!
Thanks for the reply. This is an old boat that has had a jib on it before (I would say a long time ago) but all that remains are the adjustable tracks with blocks mounted on the sail track for the trapeze. Basically I need to know how the jib is raised and secured as I have the jib and sheet ropes. Are there any pictorial images showing this? Finally do you need batons in the jib?
On the newer Mossies people don't use block tracks on the hulls but rather have eyelets in the tramp. Our older boat (1434) has block tracks and I can send you some pics if you like.
As for the jib halyard and luff tensioning, well everyone has different ideas on that! The best idea would be to have a look at a few other boats and see what appeals to you. If you come to the Nationals at Moordialloc you will get plenty of opportunity to check out that sort of thing.
- 1,312 Online
